97 sc300 LCA bushings?
I need to replace the lower control arm bushings on my car, does anybody know what place I can get some other than the dealership? From what I read apparently the Prothane bushings don't work on 97..
I already gave you the brand, feel free to look it up like what i had to do when i needed new bushings welcome to CL.
but if you insist tmengineering sells them, and there are threads and threads on how to install and remove them and threads on what the difference is between the 92-96 and 97-2000's.
You will need to have a press for the bushing but you need to burn out the old bushing because you need to keep the outer sleeves of the bushings. If you press out the old bushing you will have a high chance of crushing the outer sleeves. You need that sleeve for the FIGS bushings. My mechanic has to fab up another sleeves for me because he pressed the old one out and crushed it.
