What strut bar to pick
Just need a little insight in picking one of these 3: trd supra strut, gtspec, or cusco alc os. I know people say spacers are needed for the trd one. Is this bad in terms of ths bars performance? And are the cusco or gtspec the same with peformance? Any clearance issues
Brand wise it shouldn't matter much. As long as the bar is solid and made of good material you'll be fine. It's only job is to help distribute chassis flex between the struts when you're going into a corner. As long as it's not flexing it'll do the job fine.
So i ended picking up a trd strut bar from mvp. My SC is a 99 so I'm gonna have clearance issues. I'm jusy gonna order some spacers instead of going the washer route. Seems safer imo. However I have one more question. I saw on another forum that a guy used the supra spacers instead of the SC one. I would think there wouldn't be a difference in the two right? The price difference is dramatic between the two, so i wanna order the supra ones. If needed the SC part# 53723-24010 and the supra is 53723-24012
i have a 93 and would also like to know what is a good bar to buy both front and back.
btw ssmith that is one very pretty compartment, i am assuming you have the intake running to a turbo?
i have a 93 and just installed a trd strut bar on mine, im having spacers made as thick as the strut nuts for it to clear the intake. if u need some let me know i can have them made cheap
thats not a stock intake though? since you put one in which did you use and how good is it really intake i mean?
also any reason why you have the cover off the engine?
i also noticed you dont have that huge metal pipes over the engine, not sure what it is probably part of the original intake
i just might looking to get it for my birthday next month, present to myself.
