Pros and Cons of Coilovers
What are some pros and cons of installing coilovers?
I'm thinking about buying some; however, I wanted to know what I would lose and gain from doing this.
Thanks!
Thanks!
coil-overs are nothing but a hassle really. When I had it, I didn't bother "adjusting the height". I just left it at the desired height and never touched it again. Every time you adjust the height, you have to get an alignment.
No one does it though. Then they cry about poor tire wear and how crappy the tires are.
Pros: Flexibility Con: Cost, loss of Sport+ mode. Coilovers are not a hassle. Once you set the desired height and alignment, you don' t need to touch it again. Not sure how it can be a hassle if you "never touched it again". However, it's there if/when you want to change the height which you can't do in a non-coilover setup. Perfect if you want to track your car. I'm sure there are people like me who does it and get an alignment depending on where I take the car.
If you don't want to lose the Sport+ setting you can get springs. Drawback will be it might take a few sets of springs to get the height you want. Most likely the boat I am going to be in.
As long as you drop it an inch or less the ride won't be too bad. Once you go more than one inch then you start losing ride quality.
