RS*R Sport* coilovers
do these coil overs mess up the AVS for the F sport?? I would like to lower the Fsport 1 inch but i dont want it to mess with the AVS?? anyone know?? any feedback would be great. Thanks
If I were to install coilovers I would just loose the function of the AVS but the other features such as "port S mode alters the powertrain for faster manual–mode gear changes and more dynamic throttle–mapping" will still work.?
hey rastaracer
is it VERY easy to get to the dampener adjustment on your coils? like i mean easy in terms of not having to uninstall anything. pics?
lowering your car you have to take out the wheels etc yea?
thanks dude
thanks dude
You do not need to remove or uninstall them to make adjustments.
If you are trying to adjust the ride height then you would need to remove the wheels to gain access to the coilover sleeves to adjust them.
It is fairly easy to adjust the dampening, the fronts are super easy but the rears you do need to pull down the carpet wall in the trunk to gain access.
If you are trying to adjust the ride height then you would need to remove the wheels to gain access to the coilover sleeves to adjust them.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
