CV Boot woes...
CV Boot woes...
i searched the forums and could not find the answer I was looking for.
So my driver's side CV Boot blew out on a turn and I had it repaired. Shop said my left side was next. I am running megan EZ coils on an AWD vehicle. Would a camber kit alleviate the stress the coils put on my CV boots? Or am I just supposed to replace them all the time? It's frustrating and I'm not even aggressively lowered. Its at stock height for megans.....
they had told me about 8 months ago that it was slingling grease everywhere and it was likely to fail. two weeks ago that day came when i heard a clunk when i was making a turn and the drivers side would shake violently whenever i would accelerate from 20mph to 40.
i read that lowering your car esp an AWD one puts a lot of added stress on them, even if aligned to the best possible rate.
What is your car's ride height from ground to fender? Most AWD members start experiencing problems when they go lower than 24.5 inches. 25 inches is kind of known to be the safety marker. How long have you been riding at that height till your CV boot failed? I've been driving at 24.75 for two years all seasons of the year and have not run into problems yet (crossing fingers)
Lowering your car in general will add strain to your cv boots regardless of AWD or RWD. Its just that AWD tend to have an earlier premature failure because of how the front suspension is set up. Also if you're whipping every turn you take that can play a part in ripping the boots as well. From what I've seen and read about if you have a AWD dont go past the 24.5 - 25 inches from fender to ground height. 24 is lowest I'd go but even that would be pushing it.
if i were to use 20" wheels instead of 19, ultimately forcing me to raise my car an inch on the Megan EZ coils, would this resolve a lot of the CV issues, and intermittent vibrations?
