Flush Spacers on Fsport Rims
#301
AKNRI (07-26-18)
#304
Your #1 Lexus Vendor
Contact us for springs and spacers!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
#305
OEM F Sport wheels with 25 mm on the front and 20 mm on the rear. Car has stock suspension and rims are wrapped in Pirelli P Zero Nero, 225/40/18 fronts and 255/35/18 rears. The rears rub when hitting dips and bumps at city speed limits, so I would suggest slowing down if possible. I say 25 mm fronts and 20 mm rears are perfect and I wouldn't go 25 mm on the rears.
Oneops (02-12-24)
#306
#307
So trying not to confuse myself so much, I'm just going to note/generalize a few things here in my comment. Feel free to correct me or input suggestions
Assuming this is applies to all IS Fsport models...
Stock Height w/spacers
H&R: 25mm F/R
Ichiba v2: 20mm F/R
Lowering on Springs/coilovers:
H&R: 25mm Front, 20mm Rear
Ichiba v2: 20mm Front, 15mm Rear
I know diff tires, spring brands and heights; as well as diff coilover brands set to diff heights affect rubbing, but did I at least get the gist of spacer sizing above?
Thanks for any input!
H&R: 25mm F/R
Ichiba v2: 20mm F/R
#308
I went with customadeonly hubcentric wheel spacers which can be found on Amazon. Brand is not too important but rather the material used. I'd look for a CNC'd 6061-T6 aluminum billet hub with a 60.1 mm hub centric ring paired with grade 10.9 bolts.
#309
truu (08-17-18)
#311
^Interesting my 20 doesn't rub in rear. I have 20/20. and i have wide shoulder (wider than stock Dunlop shoulder) Firehawk tires in stock size too. and it's lowered and w/ hard cornering. Maybe yours is slightly lower or your rear wheels have slightly more positive camber?
#313
I'm new to the mod world (and not really planning to go crazy) but looks like spacers are quite easy to do self install as long as I have wire brush, some brake cleaner, anti-sieze and torque wrench, right? I will leave rsr down springs for the pros at shops take care..
#315
Do you happen to have the exact links for both the 25mm and 20mm spacers? The amazon search was a little confusing when trying to find the right sizes... Also, you're IS is not lowered?
