IS250/350 F-Sport front sway with IS-F rear sway, Best Balance?
Yes, I'm using a 1.5 way. The details I provided in my previous post regarding my experience with the Front/Rear F-sport sway bars as well as the full F-Sport suspension kit was based on when I was using the open-differential. From my experience, the car felt very neutral around the corners and only exhibited mild oversteer when I applied the throttle and the extra power was going to the inside wheel.
Sounds like you and your passenger had a blast at that AutoX event!
BTW, you get get rid of that annoying "Caution- I Agree" screen on your Nav by updating your Nav disc to a 2008 or above version. You can find an 08 or 09 OEM Nav DVD for dirt cheap on eBay. Trust me, it's well worth it!
You can try checking out Sewell, which is one of our CL vendors: http://is.sewellparts.com/.
On the top-right, you can register for an account using your existing ClubLexus info and then you'll get exclusive discounts.
FD3SISF
05-04-14 12:59 PM
CAN-Other FS: F-Sport Sway Bars
twenty
18
09-07-11 02:31 PM
