Is350 awd rotors confirmation!
CAN ANYONE POSITIVELY CONFIRM THAT FOR THE 2010+ IS350'S, THE AWD AND RWD FRONT ROTORS ARE THE SAME
I know that for the 250's AWD/RWD are not the same, and the 2006-2008 is350 rotor are different BUT everywhere i go, including SWELL LEXUS, TIRE RACK, AUTO ZONE, ADVANCED AUTO, all have the same part numbers for the AWD and RWD models for 2010 and up
I tried to call the Lexus dealership parts department but they told me that the AWD and RWD OEM part numbers are different.
Can anyone POSITIVELY confirm?
Keeping it Real
There are 2 types of IS250 front rotors and 3 types of IS350 front rotors. They vary between years and models, as well as what country the vehicle was destined for.
IS250:
06-08 are all the same (28mm thick, non-directional cooling vanes)
09-13 Canada-spec are the same as 06-08
09-13 USA-spec are different than 06-08 and 09-13 Canada-spec (32mm thick with directional cooling vanes)
RWD and AWD makes no difference for the IS250.
IS350:
06-08 are all the same (30mm thick, outside-rotor centre vented hub, directional cooling vanes), will not fit AWD models.
09-13 Canada-spec RWD are the same as 06-08, will not fit AWD models.
09-13 USA-spec RWD are different than 06-08 and 09-13 Canada-spec RWD (inside-rotor cooling vane vents), will fit RWD and AWD models.
11-13 AWD are the same as 09-13 USA-spec RWD (inside-rotor cooling vane vents, more clearance for the AWD hub), will fit RWD and AWD models.
Part Numbers (IS250):
43512-30310 - 06-08, 09-13 Canada-spec (RH & LH Same)
43512-30320 - 09-13 USA-spec (RH)
43516-30010 - 09-13 USA-spec (LH)
Part Numbers (IS350):
43512-22260 - 06-08, 09-13 Canada-spec RWD (RH)
43516-22010 - 06-08, 09-13 Canada-spec RWD (LH)
43512-30350 - 09-13 USA-spec RWD, 11-13 AWD (RH, replaces 43512-30340)
43516-30040 - 09-13 USA-spec RWD, 11-13 AWD (LH, replaces 43516-30030)
I hope that helps!
Jeff
IS250:
IS350:
I hope that helps!
Jeff
Thanks man, thats what I figured. I've been trying to get a clear answer for this for the longest time but no body had one. Now I can order my rotors knowing that 09-13 IS350 are the same. Thanks
afusco1222
04-23-14 01:07 PM
