Tein S Tech Lowering Springs
#68
Can s tech springs only be used with 19" wheels or can 20" fit? I find mixed answers on this, and i also feel like a 19" wheels is still too small for the gapping. The FSPORT wheels are a 19" and i feel like you should be able to get bigger then that size with these springs? Please help me!!!!
#69
#71
No I don't but I have a bunch of pics on my Instagram but I can't post my name cause it has a curse word in it so the forum doesn't allow it lol. Hash tag #velgen and my white 350 f with matte silver will pop up it's the only one with matte silver
#72
Thinking about getting these springs so naturally, I'm doing a lot of research. Do these really affect the camber? Does anyone have info on how much worse the camber is when compared to spec/stock?
#73
Recently got an alignment after installing the springs. Camber is -1.3 and -1.1 Fronts (spec is -1.4 to 0.2) and -2.4 and -1.9 rear (spec is -1.9 to -0.4) Only my driver side rear was out of spec..
#75
Is350 f sport my
Spec after tien s tech springs and 19 inch rims the from is at driver side -.96 and from passenger -1.16
Camber In rear driver side -1.37 and passenger rear is at -2.66 this is after alignment the toe is set perfect but seems like the car pulls to the right a tad bit but I guess that's from the negative camber in the rear. You will DEFINATLY have camber issues when you lower the car because there aren't any rear camber arms available for the car yet. My off set on my 19 are so aggressive I need a little bit of negative camber for the tires to fit. The tires are stretched on a 10.5 in rim 265-30/19 but I have about a finger in between my fender and tire In rear so when camber arms are available I'll slap some on but only will be able to mabee get another degree before it rubs so I'll still be a lil negative camber in the rear. I'm not looking over typing errors lol
