Tein S Tech Lowering Springs
Old 02-27-15, 12:37 PM
  #121
Letsstance
Letsstance's Avatar
Can't believe the rear spring install is so involved! I installed S Techs on my 06 G35 coupe and it was just one bolt to lower the spring bucket and throw the new spring in. Took about 15-20 minutes for each rear side.
Almost looks as if it's the same process with this car, except one extra bolt because the shock is actually mounted on the spring bucket...so is removing all those sway links and ball joints necessary on the rear install? hard to tell from pics. Thanks!
Old 02-28-15, 03:56 PM
  #122
CLUM
CLUM's Avatar
rear is pretty easy, take a look at my write up:
https://www.clublexus.com/forums/sus...intensive.html
Old 03-11-15, 10:03 AM
  #123
Letsstance
Letsstance's Avatar
great write up..bookmarked. thanks
Old 03-11-15, 02:10 PM
  #124
EJ255t
EJ255t's Avatar
Originally Posted by amoney805
That is a 350 based on post #14 in this thread. https://www.clublexus.com/forums/sus...questions.html
its a IS350, you can tell from the brakes.
Old 10-23-15, 12:42 PM
  #125
IvVaum
IvVaum's Avatar
Hey everyone…so today i was gonna buy me a set of these from one of the forum members on here…part number is: SKL90-AUB00
and so i called TEIN customer support and they said that it will absolutely not fit the AWD…and that it is only for the RWD…the rep said that the mount for the rear is different in the AWD from the RWD…so i ask mount? what mount?…and he goes he doesn't know, that's all their notes says…
so my question is…what is the difference between the RWD and AWD suspension mount on the 3IS?
i thought they both share the same suspension, front and rear?…can someone with a RWD take pics of their setup so that i can compare it with my AWD?
it would be sooooo much easier if there was a service manual for this car...
Old 02-11-16, 11:32 AM
  #126
jorgie523
jorgie523's Avatar
Originally Posted by SGIS14
this one is lowered on tein s techs
What size wheels are you running
Old 03-07-16, 05:44 PM
  #127
Chrispies
Chrispies's Avatar
Installed S-Techs about 2 weeks ago so it's just about settled.
Attached Thumbnails Tein S Tech Lowering Springs-img_20160307_173811.jpg   Tein S Tech Lowering Springs-img_20160307_173756.jpg
Old 03-08-16, 10:54 AM
  #128
jorgie523
jorgie523's Avatar
What size wheels are those?
Old 03-08-16, 10:56 AM
  #129
Chrispies
Chrispies's Avatar
19x8.5, x10
Old 09-14-16, 01:44 PM
  #130
E46CT
E46CT's Avatar
Received 2,183 Likes on 1,638 Posts
Here's the H-Techs on mine for anyone interested. (H, NOT S)
Old 10-20-16, 08:37 PM
  #131
3actual
3actual's Avatar
it looks great. I'm torn between H Techs and half downs...
Old 10-21-16, 09:09 AM
  #132
E46CT
E46CT's Avatar
I believe they're the same really
Old 10-21-16, 05:39 PM
  #133
3actual
3actual's Avatar
As far as drop is concerned I agree. Ride quality and preference might be another story.
Old 10-24-16, 10:30 AM
  #134
E46CT
E46CT's Avatar
If i'm not mistaken the spring rates are nearly identical with the Teins being harder in the rear and the RSRs softer in the front. Don't think you'll be able to notice a difference, really.
Old 03-19-18, 08:22 PM
  #135
Michael250
Michael250's Avatar
Default does year matter?
I own a 2011 Is250 and im thinking about buying some Tein S lowering springs, this guy is selling some that he was going to put on his 2015 is250, he tells me that they will fit on my 2011 just fine. i would feel much better if i got a reply from one of you guys telling me if this is true or not before i buy something that wont ft on my car. Thanks! Michael
Quick Reply: Tein S Tech Lowering Springs
