Weird brake problem
Hello, so I just finished my ls400 bbk upgrade (at last only took a month to get 2 banjo bolts from japan)
I bled the brakes and all that fun stuff.
But here is my problem, when I first start to brake the pedal goes to the floor, but once I let it come back up and press it again I have amazing braking power.
What could be causing this?
yes.
I did it in this order.
right rear, left front, left rear, right front.
im wondering since the master cylinder ran dry, if something is wrong with that or maybe something with the abs unit?
it wouldnt cause his problem either way but i am pretty certain the lines start from the master to left front then to right front goes straight back the right rear then over to left rear making the left rear maybe the other way around i cant remember but it wouldnt cause his problem either way
czechers (06-08-24)
