|| FIGS Engineering 3rd Gen IS Suspension and Brake Development Thread ||
#32
We are always driven by demand and pilot customers. So if you are ready we can start on it.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#34
Bump for below...I just bought the front lower arm bushings http://shopfigs.com/v1/index.php?rou...product_id=235 and will see how it does with the inner tire wear as I'm putting on brand new tires with these bushings running RSR down springs.
http://shopfigs.com/v1/index.php?rou...product_id=197
Would this work to fix my camber in the front? 3IS IS350 F-Sport
#35
#36
it should fit stamped steel arms, but the aluminum arms require a different bushing. Working on it.
Mike
Mike
__________________
#39
Received 1,736 Likes
#40
'This is our latest "Essential Kit" offering. We can also combine with swift lowering springs. The website is going through another update and things will be current early next week.
__________________
#41
Just wanted to thank you guys! I’ve just done the Lca bushings. I was a bit worried about the wear at 10k I found in the frt. I have noticed it on the rear too I’ll look into a fix for that later. But the feeling driving the car now is a massive difference. It’s So goood! The steering felt so muted and laggy on input before. It’s a lot lighter feeling going lock to lock. Noticed it right away pulling out of the driveway. Just did a little test drive and it feels now how I’d expected it should have been. So responsive on turn in now. I’m not feeling like I’m having to add more input after I turn in like I was before. I turn and the car does it and feels instant. It’s fanfreakintastic plus I’ll get better wear now too hell yeah!
Epik
02-14-10 09:48 AM
