Fit Kit & Shim Kit
Old 01-03-14, 09:51 AM
jvmagic
jvmagic's Avatar
Question Fit Kit & Shim Kit
Hi,
Do you have to replace the Fit Kit and Shim Kit (doing rear brakes) or can I use the same ones? Car has 22k miles...2010.
Thanks in advance
Old 01-03-14, 09:56 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
You do not need to replace these parts unless they are missing or damaged. At 22k miles it is highly unlikely you would need to replace either of these.
Jeff
Old 01-03-14, 10:19 AM
jvmagic
jvmagic's Avatar
Jeff
Thank You!
Old 01-03-14, 10:35 AM
Jump2man3
Jump2man3's Avatar
Jeff
Yep you should be fine. Maybe check see for any damage but I dont see any issues or reason to replace
Old 01-03-14, 03:29 PM
Gville350
Gville350's Avatar
Agreed! I'm now on my third set of rear brake pads and I'm still using the OE set of shims/hardware. I do have a new hardware kit in the garage ready in case I need to replace something though.
Old 01-03-14, 04:26 PM
jvmagic
jvmagic's Avatar
Would it be ok to replace my rear pads with a set from Autozone? These are $49 and come with all the hardware (seems to include what I originally inquired about). If not, would the pads from Sewell parts be better and worth the wait and extra $20. If a difference then I can wait for to order from Sewell.
http://www.autozone.com/autozone/par.../N-jwnuhZ8ko2a
Duralast Gold Cmax/Brake Pads - Rear
Part Number: DGC1113
Warranty: Limited Lifetime
Notes: Ultra Quiet with patented nitrile rubber shim. Disc hardware included where required by OE.
Old 01-03-14, 06:04 PM
4TehNguyen
4TehNguyen's Avatar
did you register your username with sewell to get their discount? The rear brake pads there are $47.62 but then you have shipping. Whatever you chose get some anti squeal grease to apply to the shims. If you reuse the old shims get some brake cleaner to clean them up
Old 01-04-14, 10:58 AM
Gville350
Gville350's Avatar
The rear pads take only 15-20% of the stopping force of the vehicle; so the rear pads aren't so important as the fronts. But a good, quality pad and matching hardware/shims should of course be used.
To answer your question, that's really up to you.
JNP1227
Suspension and Brakes
05-08-18 04:08 PM
lexus7217
SC430 Classifieds
06-02-17 11:23 AM
hung8852
05-28-11 07:39 PM
sbgs400
05-25-08 11:53 AM
maximussp
01-27-08 01:31 AM
Quick Reply: Fit Kit & Shim Kit
