Megan Front Upper Camber kit question..
Just installed mine, I also installed BC BR coilovers at the same time so putting them on when the shocks are off is much eaiser, you also need a ball joint seperator. Here are a few pics. There isn't much room at the top with the shock in. Also I put mine on like they came from the maker and there seemed to be positive camber. I have moved them 3 times and still haven't got the - camber I want yet. I would adjust them so the ball joint is flush with the end of the arm, you'll see what I mean, just loosen the allen bolts and push the ball till the edge is flush with the arm.
I also used the stock nut and clip on the ball joint end as the nut has a nice built in washer and the clip is also nice if you don't bend it. I got the ball joint seperator at autozone, they rent tools, it is the larger one of the two they rent. Also get a 5mm allen socket on a 1/4 inch drive and you make life alot eaiser adjusting it.
Also the torques are 36 ft lb for the top bolts and 64 ft lb for the lower.
https://www.clublexus.com/forums/sus...ere-first.html
No need for the ball joint separator; just remove the securing clip and loosen the nut until the nut is flush with that of the ball joint bolt. Then hammer on the end there with a 5lb BFH. But besides that, it's really a bolt-off/bolt-on affair. A ratcheting 12mm/14mm wrench (I forget which size that bolt is) will be your best friend with this project too.
GL!
GL!
GL!
GL!
I didn't take any pics but here's what happened. Everything started off fine at first with taking off the wheels wheels. Both wheels off, both sides are supported and so we start taking off the Driver side UCA... Problem was we took off the UCA from the body first which in my opinion was not good. So it's off but still connected to the (knuckle?) We take off the cotter pin and crown nut And we try to separate the two but for everything in the world it does not come off.. I was pretty sure u could hit the bolt upwards and it would just come out but it didnt. So I'm say to my friend "Let's go to auto zone and rent a ball joint separator" we leave and come back and try to use it but it's not coming out....and this point we are tearing up the stock bushing pretty bad... so we are like wtf is wrong with this. .. should have been way easier... so we go back to auto zone and end up renting this spindle thingy... doesn't work either... just about ready to give up. . We try the other side... But this time we SUPPORT the whole wheel hub and UCA buy jacking it some to help support it... and we started by undoing the cotter pin and crown nut... then I decide I would just try to happen that bolt out... and up it pops out like nothing and there you have it.. didn't need any special tools... Just a hammer to get it separated...
