My options for lowering my car, Help!
Is just me or are the rears of this setup sit lower then the front??? ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Yep, here's mine on Supra Bilstein struts and Eibach lowering springs. I'd recommend this for anyone that wants the stock ride quality but an obvious drop all around. It'll only cost ya about $450 new or you could get lucky and find a used set for less.
On a side note my wheel setup is similar to yours, 18x9.5 / 8.5 with 5mm spacers all around. I only rub on rough hits like pot holes![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
![](http://i75.photobucket.com/albums/i310/a92drls/Sc3/20131205_135427_zpsj8b4o5eu.jpg)
![](http://i75.photobucket.com/albums/i310/a92drls/Sc3/2013-08-18132421_zps649f2a92.jpg)
1JZ Single SC400
I say the two options for the best drop when on a budget: MKIV struts and Eibach/Tanabe springs or Esplier springs. I have the Esplier springs and love it. I would also do the harness mod. You will thank me later. One big bump and you will be changing out fuses or calling a wrecker to get you home. Good luck and let us know what you decide.
you can also get the CXracing coilovers for about 630 dollars if you save jus a tad bit more money. but you will prolly have to get your fenders rolled. ill be getting a similar set up but with a very slight stretch on the wheels.
Here is the link with a picture. The front settled about another .5"-.75". The marvelous ride comes from the new shocks i put on for the front as well. It stays flat and is stiffer than stock for sure. It's a nice way to lower it and not spend beaucoup money. I honestly would like the front to go down another inch or so though...
https://www.clublexus.com/forums/sus...-on-sc400.html
