Castor arm slid off bushing...
I installed poly castor bushing on my 00 gs3 two years ago. Recently they have been creaking bad so while I was in the process of installing my LS4 calipers, I checked the condition of the castor bushings. To my surprise they looked fine except for the fact that the bushing is half way popped out of the bottom of the castor arm. It appears that the bushing just doesn't have enough flex when jacking up the car. I will be going back to hardened rubber. I am curious if anyone has had similar problems??
I had them about 3 years ago and absolutely hated them. They knocked like no other. When I had them pressed out, the poly was contorted. Went with Roca (OEM type) and have been fine ever since. That was in 2011. I do not recommend poly bushings for the caster arm on for these cars. They are clearly not meant for the car. My opinion.
Do you have pics?
I believe FIGS has solved this problem with the Sandwich and Press-in Polys from the past.. as they dont allow the correct swing of the arm
http://shopfigs.com/v1/index.php?rou...product_id=231
[QUOTE=850Lexus;8329696]I wont ever get poly bushing again. They have been annoying from day one.
I've other people complain about the daizen's in the past also... I guess your best bet is to get the 2003+ caster arms or the FIGS... Sewell sells the correct ones...
I think I am going to pick up some of the Figs bushings. I will check Sewell as well. With my discount, they tend to be priced very similar aftermarket parts. Love me some Sewell!
Well I saw the diy stickies and I did a few searches and really didn't run into the posts about the down side.
By the way, how long do Daizen bushings last before they start giving you trouble?
I have a 2001, GS3, do the 2003 Castor Arms (Lower control arm #2) have any fitment issues. Did Lexus upgrade the bushings?
Thanks, trying to read and search all I can before I decide to go OE or Figs.
guys we have more 2001+ bushings on their way. Should be wrapped up at the end of the week and air shipped to us. This is the big problem with the design of both the lower cost alternative poly bushings. Poor material that has to deform to function and will obviously find its way off of the small lip feature that holds it in place. WE have the adjustable version in stock that will add more caster for performance. So all up to you.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
