Need RUCA Help PLEASE
Old 01-20-14, 08:26 AM
TySpeed03
TySpeed03's Avatar
Originally Posted by FIGS
the thing you need to watch out for is axle length. If you push inward too much you will compress the axles into the diff and cause premature failure. Are you trying to add negative camber or correct?
Negative Camber
Old 01-20-14, 09:57 AM
FIGS
The Maker
FIGS's Avatar
Originally Posted by TySpeed03
Negative Camber
so why not get one of our VIP kits and do it correctly. Our VIP setup offers enough clearance to fit some very aggressive fitments.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 01-20-14, 11:40 AM
marshun
marshun's Avatar
I'm going Silk Road. I have rca's but I needs just a tad more. I have Silk Road stuff for my other car and I've got no complaints. Also the silks will be easier to work with.
Old 01-20-14, 01:44 PM
TySpeed03
TySpeed03's Avatar
I have lowers now but RUCAs give you more clearance for aggressive wheels but thanks for the advice.
I think I'll do silk roads too
Old 01-20-14, 09:52 PM
FIGS
The Maker
FIGS's Avatar
so you are going to drop $1200 on a set of uppers just to be JDM? I will custom make a set for that price
__________________
Old 01-21-14, 10:22 AM
TySpeed03
TySpeed03's Avatar
it's not to be more jdm Lol , it's to have more clearance for lower offset wheels.
Old 01-21-14, 01:47 PM
FIGS
The Maker
FIGS's Avatar
I understand the goal, I am just curious why spend that kind of money when there are other solutions that are less expensive where you will get better support. We specialize in custom products and build one-off setups frequently. An upper is pretty tricky to install on-vehicle anyway, so we would do a static offset upper and add more dynamic adjustment on the lower. It would likely be slightly more than the Silk Road solution upper alone and offer a much wider range of adjustment. The bushing solution plus the lower affords a substantial amount of clearance for low offset rims and does not risk the axle strain from doing the upper alone. The key I have found with VIP cars is flexibility. Flexibility to run different wheels in the future and to fine tune the existing setup for a range of ride heights.
And FWIW, I cannot stand the term RCA for what companies are doing for the rear. These are simply drop arms, they do not change roll center since its a single connection to the outer spindle. A front RCA is actually adding length to one leg of the triangle on a double wishbone. A drop arm is just changing the connection point of the shock to change where it centers its stroke.
__________________
Old 01-21-14, 01:53 PM
porn-adkt
porn-adkt's Avatar
FIGS = Love
Old 01-21-14, 03:15 PM
TySpeed03
TySpeed03's Avatar
I understand the goal, I am just curious why spend that kind of money when there are other solutions that are less expensive where you will get better support. We specialize in custom products and build one-off setups frequently. An upper is pretty tricky to install on-vehicle anyway, so we would do a static offset upper and add more dynamic adjustment on the lower. It would likely be slightly more than the Silk Road solution upper alone and offer a much wider range of adjustment. The bushing solution plus the lower affords a substantial amount of clearance for low offset rims and does not risk the axle strain from doing the upper alone. The key I have found with VIP cars is flexibility. Flexibility to run different wheels in the future and to fine tune the existing setup for a range of ride heights. And FWIW, I cannot stand the term RCA for what companies are doing for the rear. These are simply drop arms, they do not change roll center since its a single connection to the outer spindle. A front RCA is actually adding length to one leg of the triangle on a double wishbone. A drop arm is just changing the connection point of the shock to change where it centers its stroke.
Very well said and I'll be contacting you soon!
Old 01-22-14, 09:37 PM
marshun
marshun's Avatar
Well I needed them ASAP and I've never had a problem with Silk Road anything. If you had a set available then I would have ordered. But apparently no one had. So I ordered from Japan.
westopill
06-26-17 05:45 PM
garbage85
07-22-12 10:13 AM
altezzaguy
IS - 1st Gen (2001-2005)
11-06-11 10:59 PM
dholic
10-16-10 09:48 PM
EastWind
03-23-09 06:34 PM
Quick Reply: Need RUCA Help PLEASE
