FinallyReplaced the Whole Front End
#31
I actually found a thread on here about a guy who was having trouble with his alignments and it turned out his inner tie rodes were bent. So it can happen, and don't rule it out.
#33
I only replaced the LBJ and outer tie rod. Those two makes a big different on how tight the ride will be. everything seems to be in great order on my car.
#34
WTF ??? I've ordered on rockauto, those are what i've received ! But the right references, the wrong parts without greasable design :
On the top, the really moog problem solver, on the bottom, a 555 in moog problem solver box !
#36
The same problem but oposite sides.
Hi rktv,
i have the same problem with this parts but i recieved opposite sides. Do you want make change?
I am from Czech Republic so the post costs will be not expensive.
Write mi a PM to change adres.
Michal
Michal
#39
The only thing I may have reconsidered, was to by the professional grade Raybestos inner tie rods. The service grades did not last too long. But you get what you pay for, and I was naive to think that the quality would not be changed due to the small difference in price.
The only thing I wish I had,was higher spring rates in the front, because the Megans bottomed at some times. I was on full stiff. I had to play with the ride height to get it perfect, but you cant go too low with megan and have good, quality ride.
grunner58
12-18-15 03:16 PM
