Upgrading front brakes to IS350?
Old 01-22-14, 06:49 AM
diverchris
diverchris's Avatar
Default Upgrading front brakes to IS350?
Hello,
I'm
Considering upgrading my front brakes only from the stock IS250 to IS350. Just wondering if anyone has done the fronts only as I don't see the point in upgrading the rears. Just wondering if there is a noticeable difference to justify the cost.
Thank you,
Chris
Old 01-22-14, 11:03 AM
reyoasian
reyoasian's Avatar
RWD should be much cheaper as there are more parts available, AWD is probably around 600-1000$
Old 01-22-14, 11:54 AM
NYKnick101
NYKnick101's Avatar
Actually not really, its all the same price since lexus made changes on some of the later models. The 09+ Rotors fit on ALL models. I have 2009+ RWD rotors on my IS250 AWD. 06-08 are the only models where the RWD rotors are different. My 350 brake conversion cost me about 450-maybe 500 on parts alone. I did the work my self so I saved the labor cost.
To the OP, check out this DIY as it really applies to All cars
https://www.clublexus.com/forums/sus...50-brakes.html
as for braking power, in slow cold conditions, its not really noticeable. But once the brakes warm up, there is a significant difference in braking power IMO. My front tends to squat a little more than before under hard braking. The one thing I didnt like is now braking in the turns feels a little unbalanced since its a larger rotor up front and the same small rotor in the back. It caused a little over steer but my AWD whips right back. Overall, is it worth the money? I would say so!
Old 01-22-14, 02:48 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The only difference between AWD and RWD is the rotors, so I don't think there should really be any difference in cost, just get the correct rotors.
Jeff
Old 01-23-14, 07:10 AM
reyoasian
reyoasian's Avatar
I actually meant used parts since there's a lot more people with a RWD IS350 since it's been out for much longer and also RWD being the bigger market
Jeff - can you confirm the red part up top? for Canada spec that is Thx
Old 01-23-14, 12:36 PM
600rr05
600rr05's Avatar
hit up a member named aliga he is based out of NY and is always selling IS350 brakes and Im sure will answer questions you may have.
Old 01-23-14, 02:15 PM
GiantsFan
GiantsFan's Avatar
Originally Posted by diverchris
Hello,
I'm
Thank you,
Chris
I only did the fronts .... you will be fine
+1 ... I got my brakes from him as well.
Old 01-23-14, 02:33 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
06-13 RWD IS350's in Canada all use the same rotors, they will not fit the AWD.
11-13 AWD IS350's in Canada have the correct rotors to fit either the AWD or RWD.
Jeff
Old 01-24-14, 11:16 AM
reyoasian
reyoasian's Avatar
Thanks, mine being 09 AWD, I'd need AWD-specific rotors, and any AWD/RWD pads then.
For upgrade to 350 brakes, I would need any AWD/RWD rotors and calipers and pads. Possibly dust shield too I'm assuming.
Old 01-24-14, 11:27 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Calipers, pads, dust shields, shims and other hardware are all the same for all RWD/AWD models.
The only thing you really need to make sure you get specifically for the AWD is the rotors.
Jeff
Old 01-25-14, 04:12 AM
iRyan
iRyan's Avatar
Hello,
I'm
Thank you,
Chris
I only upgraded my fronts to the 350 brakes....I dont think the rears is needed IMO...waste of money for rears
Old 01-27-14, 07:32 AM
mikellucci
mikellucci's Avatar
The ISF rear calipers actually look GREAT with the IS350 Advics front calipers. Thought I had a pic here when I briefly had the setup on my IS350 but guess not. Oh well
JaeISF
Suspension and Brakes
03-04-18 06:12 PM
fewslowcar
17
03-05-15 12:11 PM
afusco1222
04-23-14 01:07 PM
GSE25
30
05-03-13 08:12 AM
diverchris
08-31-12 03:01 PM
Quick Reply: Upgrading front brakes to IS350?
