Help with brakes and rotors on 2009 IS250
Old 06-28-24, 06:15 AM
redidnarb
3rd Gear
redidnarb's Avatar
Default Used Centric 60-28 instead of 60-32 rotors
Hi Jeff,
Hoping you still get notifications and respond!
I accidentally bought the 28mm brakes and rotors package from RockAuto. The brakes didn't fit my car, but the rotors looked the same to me so I used them and bought brakes from store. I later found specs and see there are some differences and wanted to get your opinion.
Are the 28 mm rotors going to be safe for us or do I need to change them back to 32 mm?
28mm front https://www.centricparts.com/disc-brake-rotor-121-44125
32 mm FR https://www.centricparts.com/disc-brake-rotor-121-44139
32 mm FL https://www.centricparts.com/disc-brake-rotor-120-44140
The picture for the FR rotor doesn't seem correct to me bc the tiny holes are not diagonal like the old 1 I have and like the left ones.
I messaged Centric and they said: Fri, 06/28/24 6:55 am Hello Brandi, We do offer directional rotors for certain models - The 121.44139 and 121.44140 have cooling vanes designed for them specifically, and don't have to follow the other look of the other rotors, so they are just a different design. They are correct though. Thank you for contacting Centric Thu, 06/27/24 4:38 pm Subject Product InformationMessage: Hello everything I've read says the rotors for cast 60-32 have 32mm rotors with directional cooling vanes and so the LH and RH rotors are different. I noticed the 2 tiny holes are diagonal on the front left but straight on the front right. I'm looking at rotor parts 121.44139 and 121.44140.
Thank you!
Brandi
JDMpeezy
Suspension and Brakes
12
11-29-16 06:38 PM
lexus832
20
10-05-14 02:01 PM
panda327
10-20-13 06:08 PM
robertrios
06-10-11 09:12 AM
JPZEE83
04-15-10 09:39 PM
Quick Reply: Help with brakes and rotors on 2009 IS250
