Fsport BBk kit not fitting 2009 Awd IS250
Old 02-02-14, 01:32 AM
JdSwiper
JdSwiper's Avatar
Default Fsport BBk kit not fitting 2009 Awd IS250
So i drove great lengths to pick up some parts off another member, one of them being front and rear Fsport BBK. He has a 2008 IS 350, I have a 2009 Awd IS250. When we went to install the shims off his car (bbk) they wouldn't line up. After looking up the part numbers for both vechicles, they seem to be the same, but yet won't fit the awd, why???? Any input from somebody experienced with the Fsport bbk on the awd would be greatly appreciated!
Old 02-02-14, 11:35 AM
mikellucci
mikellucci's Avatar
Part Numbers are the same for Front BBK according to Sewell. Rear p/n are different but not sure why. What I found looks conflicting.
IS250/IS350 Front - PTR0930102
IS250 Rear - PTR0953109
is350 Rear - PTR0953110
Where did you have problems? I know for a fact the RWD knuckles are the same between IS350 and IS-F. The shims with the FSport bbk are the same and they aren't side specific...they should bolt on if the knuckle is the same.....they may be different though between AWD and RWD:
Was the issue up front with the knuckle? They are different between AWD and RWD it looks like-
Knuckle Steering 43211 and 43212
IS250:
Left - 4320153020
Right - 4320253020
IS350
Left - 4320153010
Right - 4320253010
If RWD knuckles solve your issue I have a spare set from the IS-F I can sell you cheap.
Old 02-02-14, 02:38 PM
NYKnick101
NYKnick101's Avatar
the 06-08 is350's rotors have different offset spacing than the 2009+. I think in 2009 is when both AWD/RWD rotors were the same so anything from earlier models wont fit
Old 02-02-14, 04:11 PM
JdSwiper
JdSwiper's Avatar
It was the fronr knuckle. We tried doing the swap yesterday!
Old 02-02-14, 04:15 PM
mikellucci
mikellucci's Avatar
Well there you go. The RWD knuckles should work for you but I'd research it further by comparing parts diagrams. Maybe ask Sewell wtf they list the front kits with same p/n as well?
I have an extra pair of knuckles from an ISF in my garage if you need them.
Old 02-02-14, 05:43 PM
reyoasian
reyoasian's Avatar
so OP came to Toronto...
Old 02-02-14, 06:59 PM
JdSwiper
JdSwiper's Avatar
O hell yea bro, all the way up from R.I .!!!! 10 hours! !!
Tried doing the swap at Igarage in Markham!!
Old 02-03-14, 12:50 PM
reyoasian
reyoasian's Avatar
straight from Jeff Lange, maybe shed some light:
Originally Posted by Jeff Lange
The only difference between AWD and RWD is the rotors, so I don't think there should really be any difference in cost, just get the correct rotors.
Jeff
^ here he is referring to is250 rwd vs awd, and is350 rwd vs awd (i think)
There are 2 types of IS250 front brakes, they either have 28mm thick rotors or 32mm thick rotors, and which ones the car has can vary depending on year and country the car was meant for. The calipers, rotors and pads all need to match. For North American IS250 sedans:
2006-2008 USA models use the 28mm rotors (produced from 08/2005 to 09/2008).
2009-2013 USA models use the 32mm rotors (produced from 09/2008 to 04/2013).
2006-2010 Canada models use the 28mm rotors (produced from 08/2005 to 08/2010)
2011-2013 Canada RWD models use the 28mm rotors (produced from 08/2010 to 04/2013)
2011-2013 Canada AWD models use the 32mm rotors (produced from 08/2010 to 04/2013)
Models with the 28mm rotors came from the factory with the high-friction (and high-dust) Textar T4146 brake pads (low dust alternatives were available from Lexus after the fact). Models with the 32mm rotors came from the factory with the low-dust NBK D6893H brake pads.
Models with the 28mm rotors use the same rotors for left and right while models with the 32mm rotors have directional cooling vanes and so the LH and RH rotors are different.
The brake calipers will have a mark on them stating which type of brakes they are (either marked "60-28" for 28mm rotor type or "60-32" for 32mm rotor type).
Old 02-03-14, 04:43 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
AWD and RWD have the same brake fitment with the exception of the front hubs needing more clearance for the rotor on AWD models.
Not sure why they wouldn't fit. Is it possible you got the sides mixed up, or something else weird? Maybe a missing part, or something else?
The caliper to knuckle fitment is the same between AWD and RWD, IS250 and IS350.
Jeff
Old 02-04-14, 07:55 AM
Jump2man3
Jump2man3's Avatar
Heres a question not sure if it was covered...Do you have the brake shims? Which come with the f sport kit..This replaces the rotor dust shield which pushes out the rotor about a couple mms which was an issue i had with my d2racing bbk.
Old 02-05-14, 04:19 PM
JdSwiper
JdSwiper's Avatar
That was the problem. The shims didn't line up.
Old 02-05-14, 04:30 PM
mikellucci
mikellucci's Avatar
So did you install them wout the shims and have enough clearance? Kinda hard to solve your problem not having information disclosed.
Old 02-06-14, 06:48 AM
JdSwiper
JdSwiper's Avatar
No, the shims that came with the bbk wouldn't line up (screw holes) We were gonna try cutting the dust shields and use those but they weren't thick enough to give enough clearance for the rotor to clear the knuckle
Old 02-06-14, 07:33 AM
Jump2man3
Jump2man3's Avatar
hMMM I had mine cut and my BBK worked perfectly
Old 02-08-14, 06:04 PM
JdSwiper
JdSwiper's Avatar
Yea I don't know what say than. Club member 149Max was the one selling them to me so he was there as well as the two mechanics .
Austin1210
06-01-16 04:37 PM
dmanmtl
02-11-16 12:53 PM
SonyHome
09-22-13 11:07 AM
Quick Reply: Fsport BBk kit not fitting 2009 Awd IS250
