Stainless Steel Brake Lines, performance upgrade or not?
Hello All,
Since I can not afford a BBK kit, I was told that going with some aftermarket rotors and performance pads will make a difference. In addition, I was told by changing the brake lines to Stainless Steel would make a considerable difference. Can anyone chime in on this? I was wondering if it's worth the money.
Hello All,
Unless you are overwhelming the brakes and experience brake fading you don’t “need” anything. If you are looking for better Initial bite/ feel on a track car then yes, tires, brake lines, brake pad compound, flex in caliper, flex in master cylinder and type of fluid will improve these areas.
So to answer the actual question: I am not sure why someone will tell you that (unless he/ she is trying to sell you these items) but, NO stainless steel brake lines will NOT make a considerable difference unless the above conditions are present and still I will not call it considerable difference, many track cars use stock lines.
Rotors? Unless they are lighter I don’t see how they are going to do anything at all under normal street driving conditions.
There is talk about stainless steel lines here every now and then. The factory lines are kevlar or something, and more than up task. Stainless lines need to be inspected more often and are more prone to failure (allegedly). The only reason to use those over the stock lines is if you like the look.
As for a BBK, the stock size on the 350's is pretty good. I've tracked mine a few times and never had a problem with the brakes. I have high carbon blank rotors and EBC yellow stuff pads. I also had the fluid flushed and put in some good high temp brake fluid. If you wanted to track your 250 I can see larger brakes helping, but the size on the 350 seems fine.
TLDR: for street driving, stock setup is fine. If something "feels" wrong, you probably need to replace something that is worn out. If you want it for the looks, do whatever makes you happy.
As for a BBK, the stock size on the 350's is pretty good. [...] I also had the fluid flushed and put in some good high temp brake fluid. If you wanted to track your 250 I can see larger brakes helping, but the size on the 350 seems fine.
Overclocker
Suspension and Brakes
09-13-05 06:02 PM
