are SPC camber kit any good?
If you are going that aggressive I might also look into the Megan Upper Control Arms for the front. Way more adjustment than the SPC kit. I think you will need everything you can get to make those work.
It looks like all you need is some adjustable front and rear camber arms. Your alignment shop will be able to adjust toe in the front. I'd suggest you get a camber kit quick so you don't kill your tires.
ekim
03-16-12 10:01 PM
