1997 SC300 Lower Control Arms. any input greatly appreciated!
Hey guys been lurking for a while doing a few DIY and would love to tackle the Front lca's myself since the shop i went to quoted me 700(Lexus Arms) each arm without the labor and well screw that I'd rather break out the elbow grease! I know your all going to tell me to use the search bar when I ask this question and trust me I have, but hasn't answered my question at all. I'm still not sure if the supra LCA's would fit my car I've seen a lot of responses to other posts that say they will and they won't which kinda has me scratching my head . If they do which ones should I buy the MKiV NA's Or the TT's and which year I believe it was 96+ or 93+. any input that would help I'd greatly appreciate guys trying to get this done this week my car has some nasty vibration on the highway everyday I take out to work feels like its going to be my last x-x
Last edited by 2jzVIP; 03-03-14 at 09:35 PM. Reason: forget to mention that it was the front LCA's to clarify
LCA's from a supra will fit. It was UCA that had some question to it. If it's just your bushings, then change your bushings. Lexus of Sewell sells em. I would just take the arms, get em pressed in at a shop then put em back on
Yeah my ball joints are bad to :/ or I would've gone the urethane route as well, thanks for the input man now I gotta check in with my local Toyota dealer and see how long it would take to get them in.
Awesome thanks for clarifying it for me. I was told my UCAs were going bad to I was thinking of buying megans or battle versions if they sell them. I'm pretty sure I'm going to need an alignment after this?
Looks ill be good with the UCA's. I also just got done talking to the one of the guys from my local Toyota dealership told me 468 for 93-95 lca 699 for 97+ did the prices really shoot up that much or am I better off finding them cheaper online?
I can confirm 100%, you can buy supra lower control arms. I just replaced mine this weekend, with 1995 Supra (TT or NA doesn't matter) LCA for my 99 SC300, and they fit perfectly. Another plus is the Supra LCA have stiffer bushings than stock SC300. You can buy them at Toyota of Richardson ask for Marvin, or Call Fred at Pat Lobb Toyota of McKinney, both great guys.
Another couple of notes, if you are doing it your self, mark the position of the eccentric bolt going through each bushing, this is the alignment marks. When tightening the bolts, make sure to jack up the assembly under the ball joint to its natural position, as if the wheel were on the hub and the car on the ground. Bushings have memory and need to be tightened in this position.
