Compatible Supra OEM Rotors for SC300
I did a bit of searching and did not find the answer I was looking for.
Will an OEM Supra replacement set of front & rear rotors work on an OEM SC300 setup?
I'm not ready to do a full brake setup swap / larger wheels as my power demand is not there.
But I did find a good deal on front & rear cross-drilled Brembo rotors for the1993-1998 Supra N/A. I have a 1995 SC300 w/ stock 16x7 wheels and have been told these will swap on without any issue but I wanted confirmation before picking them up.
Otherwise picked up a "display" set of Tein CS coil-overs today, figured I'd replace the stock rotors and pads when I'm down there.
Appreciate any help.
Perhaps a stupid question then . . .
SC300 OEM rotors are 275mm front and 290mm rear
Supra N/A OEM rotots are 296mm front and 207mm rear
Is this too great of a size difference to use on the SC300?
peanuthead
SC400 / 300 Classifieds
02-03-07 10:42 PM
