Question For Those Running MOOG Ball Joints/Tie Rods
Old 03-21-14, 07:15 AM
Aristo722
Aristo722's Avatar
Originally Posted by FlockoV8
Spray some grease in the caster arm bushing see if it temporary goes away..
Like WD-40 grease? Or something else lol
Old 03-21-14, 06:37 PM
PlatGS3
PlatGS3's Avatar
Originally Posted by Aristo722
Im not sure, It has brand new SPC front upper control arms, MOOG ball joints, tie rods, and Megan coilovers. But I'm getting squeaking when I drive. When I hit imperfections in the road, bumps, and stuff. Even when I open the door and sit in the car, I hear it do a quick squeak. And i'm pretty light, i'm only about a buck 35 and it squeaks when I sit in the car, or even sit on the fender/hood. I'm assuming it has to be some bushings. But where to start? Sway bars? Rack and pinion?
I have the same issue about the noise. I jacked up my car and rotated my spring on the coilovers about half a turn. The thin rubber gasket thing that sits directly on top of the coilspring is worn. Once I rotated out of the way and lowered the car down the noise stopped. Maybe give it a shot ?
Old 05-03-14, 05:23 PM
joboo
joboo's Avatar
I know what you mean about a squeak. I just did ball joints, tie rod ends. sway bar end links, roca caster and lower control arm bushings and it still squeaks- Im thinking it must be upper control arms next. The problem is the car is so quiet I hear all little squeaks.
Old 05-04-14, 12:18 AM
DosyBoy
DosyBoy's Avatar
Sure, stopped my squeak with wd-40 on the caster arm bushing, sprayed a lil In there and the noise hasn't returned since, it's been about a good 5-6 months...
FiveSeven
12-06-19 03:42 PM
luda42688
Suspension and Brakes
14
03-08-16 02:17 PM
qwerty04
12
01-24-13 03:31 PM
socalturbo
08-06-10 07:37 PM
CantSeeMe
02-11-08 01:41 PM
Quick Reply: Question For Those Running MOOG Ball Joints/Tie Rods
