RS*R Super Downs Installed (tons of info)
Old 01-11-17, 11:41 PM
  #61
Boomin
Boomin's Avatar
With super downs, aren't they best accompanied with camber kits? And on stock wheels, any rubbing? Issues?
thanks
Old 03-19-17, 06:46 AM
  #62
Bertin3ISF
Bertin3ISF's Avatar
RS-S Half Down
Lexani 20x8.5 front and 20x10 rear
Old 04-02-17, 09:27 PM
  #63
3ISOwner
3ISOwner's Avatar
How's everyones stock struts holding up on Downs/Super Downs? How many miles has everyone driven so far on RSR springs?
Old 05-11-17, 05:52 AM
  #64
LexoticJ
LexoticJ's Avatar
Originally Posted by Bertin3ISF
RS-S Half Down
Looking good!!
Old 05-11-17, 06:42 AM
  #65
Bertin3ISF
Bertin3ISF's Avatar
Originally Posted by FreshIS250
Looking good!!
Thanks bro!!!
Old 05-11-17, 07:56 PM
  #66
Solara350
Solara350's Avatar
Originally Posted by larry13
rsr coils... you wont regret it :-)
100% agreed ! If he really wants it so lower he should go Coilovers or air suspension ! 1" inch drop with spring is fine though
Old 02-13-18, 02:01 PM
  #67
naloxon33
naloxon33's Avatar
Hi there!
Sorry for disturbing but do you have any photos of your IS 350 AWD on RS-R Downs? How big was the gap between the tires and wheelbase? Or any photos with the RS-R Super Downs? I am really looking forward to them because I would like to get the RS-R Downs too but I don't know how big is the gap will be on a AWD IS 350?
Thanks a lot!
Old 04-18-18, 03:20 PM
  #68
jtrinh
Registered User
jtrinh's Avatar
Following, been looking seening if anyone has ran 20’s yet perferringly 20x9 20x10.5 other wises ill be running 19’s rsr super downs is just a temporary situation for me for now
Old 05-19-18, 03:47 PM
  #69
jeppoy01
jeppoy01's Avatar
Default Rsr super down on 18 is350 awd fsport
Hey guys just wondering for the new 2018 is350 fsport if the rsr super downs work for the new 18s. Few people have told me the 18s are diff from the 17s just wondering if anyone here with 18 is350 have lowered there car with rsr super downs?
Old 07-30-20, 10:24 PM
  #70
4Infiniti
4Infiniti's Avatar
Default What were your stock floor to fender measurements?
Originally Posted by jaznraz
I installed Super Down springs on my RWD 350 F-sport last weekend and wanted to share some thoughts, information, and pictures.
The drop - measured from the floor to the fender:
front left = 24.68 (2.13 drop)
front right = 24.75 (2.18 drop)
rear left = 24.56 (1.75 drop)
right rear = 24.68 (1.75 drop)
Suspension travel - I took the springs out of the car and raised the suspension to check the max suspension travel. This is the point where the bump stops are fully compressed far enough to raise the car. After taking a few measurements, the front suspension has .75 travel from static height to max suspension travel and the rear has 1.25. Keep in mind, this is not to the point where the bump stops hit, but to the point where the bump stops are fully compressed. BTW - the bump stops are on the shock assembly. RSR does not recommend cutting the bump stops.
When looking at the Super Down vs Down spring specs, I was shocked the SD springs had a softer rate. I called RSR and asked about this and they said the specs are correct. I commented that it didn't make sense for a shorter springs to have a softer rate, however, I believe that I understand what's going on. Due to the info listed in the previous paragraph, I'm certain that the bump stops are in full contact all the time which in turn makes them act like a spring. This would be a reason why the SD springs are softer than the down springs. I might be completely wrong, but it's my theory. I could have verified that by taking a few more measurement, but it's too late now.
Alignment
There is no camber adjustment on the front or rear of the RWD cars. I subscribed to the Toyota Tech Info System (TIS) and it's stated plain and simple. There is, however, camber adjustment in the front for the AWD cars. So, all I had to do was check and adjust the toe which made the alignment process a lot easier. My rear toe was in spec after the drop (shocker), but the front needed to be adjusted.
front camber = 1.7 and 1.7
rear camber = 2.4 and 2.6
I don't like the rear camber but the only way to fix it is to raise the car.....that sucks!
My thoughts:
The drop looks absolutely bad a$$!!!! The ride isn't too harsh, but I'm not going to say more about that until I've put more miles on the car. I don't like the scenario of riding on the bump stops (if that is the case), and I don't like the rear camber.
My setup:
Stance SC-6 wheels with Conti DW tires
235/35/19 on 8.5+35 wheels
265/30/19 on 9.5+40 wheels
Here is some info about tire sizes I posted yesterday. https://www.clublexus.com/forums/is-...wered-3is.html
Last but not least:
what were these stock floor to fender measurements?
Todd Edge
Suspension
02-09-12 07:04 PM
FXAuto
Club Lexus Vendor Marketplace
01-13-11 06:31 PM
eggwoll
Suspension and Brakes
15
01-27-10 11:00 PM
dat-is350
01-04-07 03:44 PM
jwar
SC- 1st Gen (1992-2000)
12-17-02 01:08 AM
Quick Reply: RS*R Super Downs Installed (tons of info)
