1991 UZZ31 Rear Brake Rotors
Hey guys,
I'm currently in need of a new set of rear brake rotors for my 1991 UZZ31 SC400 and I'm just curious as to which are best and where is the best place to buy them?? It's just a stock standard daily driver so I'm not after anything crazy. I've also had a look on eBay and there's a few RDA sets around for ~$200 but I'm not sure which would be best seeing they all have different part numbers but all say they'd suit '91 sc400/soarers...
Cheers,
Brad
Cheers,
Brad
If Memory serves me correctly...
UZZ31 means you have Air suspension and your vehicle is a Soarer (right hand drive)
your rear Rotors (discs) are 291mm in size IIRC.
42431-24021 is your part number from Toyota -
Unfortunately the US SC400 used larger rear rotors. BUT the US SC300 used the same sized Rear Rotors in early production years.. So price out that part number or use a 1992 SC300 as the car you have...
Now I have no idea where ACT is... so if you help clarify that I can be of more assistance....
And it sucks when Places online use terms like SC400 when referring to a Soarer.. as they are still very different when it comes to part numbers, options, etc even though many items do cross over. so I get you on how it can be confusing and wanting to make sure you get the right items.
Hey,
Sorry I should have specified better. I'm living in Australia. So my car isn't actually an sc400(fairly certain) so I should be able to just score a set of soarer rotors. I just saw a set of RDA rotors with the right diameter (291mm) so I'm thinking they'll be the go as they're pretty well priced. Cheers for the info with sizing and what not.
