J5 suspension type JS coilover
Old 04-05-14 | 02:23 PM
J5usa's Avatar
J5usa
Default J5 suspension type JS coilover
INTRODUCING - Type JS
For the 3rd Gen Lexus IS our Type -JS is made with 7075 aluminum. meaning lighter and stronger than 6061. equal = 17.5kg
Height adjustable
MONO TUBE GAS Shock observer.
Special 7075 Aluminum alloy cylinder(Maximized wear resistance by special anodizing treatment).
12 stage damping force adjusting(Patented Precise damping force adjusting technology).
bracket, link, ring, base, upper mount from 7075 aluminum
spring rate: 12kg front, 10kg rear - lower or higher kg spring available upon request.
IS 250/350 RWD&AWD. available - retail $2250
Fsport w/ AVS (currently in R&D, expect to be released end of April) - retail $2500
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 04-05-14 | 02:39 PM
jaznraz's Avatar
jaznraz
Price?
Spring rates?
Available now?
Warranty?
It appears you can adjust the ride height with one adjustment and then adjust the bump stop position with a secondary adjustment. Please verify this.
Old 04-05-14 | 04:15 PM
J5usa's Avatar
J5usa
Originally Posted by jaznraz
Price?
Spring rates?
Available now?
Warranty?
We are currently offering a special CL member to Introduce J5. $1350 for limited time.
Spring rate: 12kg front and 10kg rear
Available: Next shipment coming in end of April to early May. (taking pre-orders)
Warranty: one year
you can purchase through
http://www.kspecracing.com/j5_suspen...t/g-74550.aspx
promo code: J5CLPD
We have RWD, AWD no AVS and currently finishing up on AVS compatible coilover system.
Lowering is same as other co. loosen the bottom ring, that locks the base while its mounted and turn the cylinder to lower or raise.
chrisvo95
02-27-18 01:07 PM
FIGS
CL Vendor Products for RC-F
14
02-15-16 02:31 PM
JE
Club Lexus Vendor Marketplace
14
08-30-11 07:45 AM
