Eibach Springs
I have the Pro-Kit and I also installed Tokico struts. I will tell you, do not do the springs on the factory struts. It will ride fine for alittle bit, but then it turn to crap. They just can take it after awhile. Just to give you an idea, the rear struts on my car were leaking when they took them off. The car has 40,000 miles on it!! Not what I expected. So that's why I say change the struts when you install your springs. The job itself was not to bad. I did not do it myself but I did see the whole process and I would have someone that has done it before do it. There seems to be a few tricks to doing it correctly. I also did the sway bars at the same time. All I can tell you is that the car should've had all this done at the factory. It rides and handles awesome. Hope all this info helps you out...
