LS400 BBK Install Trouble
Working on installing my LS400 front calipers and ran into a small speed bump.. Everyone says it's all a bolt on deal after removing the dust shield and spacing a caliper bolt but the issue I'm having is the brake lines don't bolt up. The nipple that is suppose to go into the caliper and keep the line from rotating will not line up for me? Is this normal or are my brake lines possibly replacements? Is this what everyone else's fittings look like?
Moved to brakes and suspension subsection.
please try and use the proper sub-forum in the future.
The nipple on the stock brake lines does not fit into the spot on the ls400 calipers like it does on the stock calipers. What I did and everyone else does is turn it slightly so the nipple is out of the way, and then bolt it down.
The nipple is not necessary and once you torque them properly they don;t really move, well at least mine have not and I have had the ls400 calipers and the stock brake lines for quite a while now.
Also note the aftermarket brake lines, do not have that nipple, its more of a factory overkill thing.
oh and one other question, When you look up the rear calipers for the LS400 there is two different sets.. one up to 6/97 and the other 7/97 and older.. Does it matter what calipers or do they both fit?
the bolts are too long, so you add washers to take up the extra length. its not difficult.
what I would recommend instead is to just get a pair of the ls400 bolts and you wont have to do that, which is what I did. you need 2 ls ones, and you reuse 2 of the SC ones without any spacing.
you need the front calipers for the LS400 brake updrade on the SC. the rear calipers do not work on an SC as far as I know.
Now my next question is if the LS Rears dont fit what are people running for rear upgrades? the TT supra's? or at that point are they just going with full TT Supra Calipers all around or aftermarket kits like willwood and stoptech?
Yes; all of those from what I have read....
People do all of these. I would recommend getting TT calipers all around. I originally got LS fronts and supra TT rears, and I noticed the TT rears rotors are actually bigger than the LS front rotors, so I'll be switching to supra TT brakes all around in the future. The supra TT brakes also offers a larger selection of performance brake pads (something the LS brakes are missing).
That was the big question for me lol. I wanted a little better stopping power but I fugure just save the few extra hundred dollars and go with TT's all around. How is the fitment and how easy are they to install? Direct bolt up like the LS's or do you need mounting brackets? Finally, isnt it necessary to run 17" or 18" rims to clear?
The front are a direct bolt on. I haven't done the rears yet, but they should be a direct bolt on too. Only thing is the dust shields will have to be cut or completely removed (which is standard for any brake upgrade). Yes, it is necessary to run a 17" or 18" wheel. The supra comes with 17" wheels stock. I have 18's from an IS350 on my car, and it will require a 5mm spacer to clear the supra tt caliper in the front.
TT supra and LS both will bolt on to the front with their respective rotors.
I like the LS brakes because they are much much lighter and have most of the stopping power, but some like the TT as they have that slight edge in performance. That being said the LS400 brakes can still lock up my front end very reliably even after multiple stops, even with regular pads. If it were a road car I would go LS400 to save weight and still have great stopping power, if it were a car that sees track duty I would lean towards the supra TT fronts as they will brake more times without fading in competitive usage.
for the rear most use the supra TT rears, doesn't matter if you have LS or supra brakes up front, they will help.
Sounds like I'll just be running the LS's up front then Ali. I plan on keeping it looking as stock as possible minus FMIC and Rims eventually lol.. Do you know if the stock Chrome 16" rims will clear the LS brakes. I have a lead right now to get a reman set of fronts for $70.00 so this little project might move along faster then I thought.
