cheap camber kit?
Old 04-16-14, 06:25 PM
2012IS250
2012IS250's Avatar
Default cheap camber kit?
So I just got my new tires today and the mechanic recommended me to get a camber kit. What's the cheapest camber kit that I can get? Is there a difference in functionality between a high end vs low end camber kit? What brands would you guys recommend? I'm dropped on H&R lowering springs so about a 1.1-1.2 drop in the front, 1.3-1.4 drop in the back. Thanks!
Old 04-17-14, 01:42 PM
Gville350
Gville350's Avatar
Save the money you would spend on the camber arms and spend it elsewhere; with only a drop on springs you'd not have to worry about mad camber wear. If anything, take the saved money and spend it on an alignment if you haven't gotten one yet.
Old 04-17-14, 01:55 PM
2012IS250
2012IS250's Avatar
I got the alignment right after I got my tires. I'm at a -1.1 degree angle for both sides.
Old 04-17-14, 02:45 PM
ISFPOWER
ISFPOWER's Avatar
thats good
Old 04-17-14, 02:57 PM
2012IS250
2012IS250's Avatar
Originally Posted by ISFPOWER
thats good
My steering wheel is slightly slanted though LOL is that normal? It was more slanted than before I got the alignment.
Old 04-17-14, 03:05 PM
WylieKylie
WylieKylie's Avatar
Camber isn't going to change the angle of your steering wheel, that suggests your toe is off, or that you possibly need recalibration with Techstream.
Old 04-17-14, 03:19 PM
ISFPOWER
ISFPOWER's Avatar
bring it back and tell them to realign your steering wheel. usually they put a tool to hold it straight forward while they make your suspension adjustments but it seems like it got loose.
Old 04-17-14, 05:39 PM
2012IS250
2012IS250's Avatar
alright yeah i'll call my shop tomorrow or something. thanks!
Old 04-17-14, 07:45 PM
Gville350
Gville350's Avatar
-1.1 degrees is like factory spec!
Old 04-20-14, 08:56 PM
LexusGuyyy
LexusGuyyy's Avatar
To my knowledge megans are decently cheap, I had to replace all of my rear suspension arms, ended up costing me $500 for all 3 due to the previous owner doing a half *** job cutting and rewelding the factory arms good luck in your hunt and happy Easter.
Old 04-21-14, 09:50 AM
2012IS250
2012IS250's Avatar
LOL but the steering wheel is slightly slanted
Old 04-21-14, 12:26 PM
Gville350
Gville350's Avatar
^That is what the shop that did the alignment needs to address. There are tools used to keep the wheel at true center during the alignment.
Old 04-21-14, 01:14 PM
LexusGuyyy
LexusGuyyy's Avatar
Just found out the Figs arms almost cost as much as megans! I wish i knew that before i went on a shopping spree!
Danilo02
Suspension and Brakes
07-16-15 11:51 PM
edgeucated
12-02-12 09:38 PM
pwrusr
Suspension
07-30-12 06:40 AM
2JZSteven
IS - 1st Gen (2001-2005)
07-16-10 05:22 PM
dave197878
04-03-09 07:15 PM
Quick Reply: cheap camber kit?
