l-springs/shocks
l-springs/shocks
I was reading a few of the threads about the steering wheel shimmy due to lowering of the car. Is this a common problem with lowering a car? I have a 99gs and wanted to lower to get rid of the fender gap and to have a better handling car. Those with 99gs' with the l-tuned upgrade, have a lot of you guys witnessed this?
you can choose few JDM springs from japan, like Espelir, kg/mm, NPG(made by bridgestone)..most of them have 40mm front/30mm rear drop..they are lower than L-tuned; but still retain stock spring rate for comfort
Re: l-springs/shocks
The shimmies (is that a word? ) are usually realted to a front end out of alignment [may be due to lowering indirectly], warped rotors, or bent wheels.
In any event, after you make changes to your suspension, or just about any handling charateristic, it is a good idea to get a 4 wheel alignment since the GS can be so finicky.
HTH
