warning brake lights comes on when on brakes but off when not on the brakes
hey guys over the weekend i swapped out my grey int for black ones not sure what i did wrong but tonight i noticed that everytime i got on the breaks the warning lights would come on and when i let off it would go away. Does anyone have any idea what it might be i tried searching but couldn't find the info on same problem any help would be great thanks.
also dont know if i am tripping but i recored a short clip to see if it was the third brake light that i did not plug in but it seem to be working but what i noticed in the clip everytime i stepped on the brakes i heard a little ping sound really curious now
I had an issue with my brake light coming on and then going out again. I have just found out that my backing plate is rusted so bad that I am in need to e-brake pads and that is the reason for my light going off. You might want to look at yours and see if it is that same problem you are having. Good luck. I hope it is not this for you because it is not cheep to replace these backing plates.
mackel53
12-14-08 12:48 PM
