advice for lowering
Kind of on the same topic...
Say like you want to lower your car so it is 26 inches from fender to group. Would springs + shocks be LESS comfortable than coilovers (assuming you adjust the dampening to the fine limit between no rubbing/comfort at that height)? Some people said coils are much more comfortable over springs, but I've only had the first so can't compare
Lower Spring rates are inherently way lower than coilovers. The higher spring rate, the stiffer it gets so the less comfortable. Look, regular spring rates are like 5-7k range while coil is in the 8-16k range. The dampening settings helps the shocks to obsorb more so you may get an illusion that coil is more comfortable. However, dampening setting does NOT change the inherent stiffness of the spring rate itself.
Also, the lower you go, the less comfortable dampening setting you can choose because you have less clearance travel for the shocks to absorb. That is why for extreme lowering, people choose even higher spring rates so that the wheels/tires won't rub against the fender but it will be very stiff.
I second this as well. If you look for extreme lower, go bag but they are not ideal for improved handling. Basically, you are paying a lot for just little handling improvement. The ones who run them are into VIP style. Springs or coil actually improve handling and track proven.
If you look for pure comfort, stock is best.
what you think about this?
http://www.ebay.ca/itm/Function-and-...6d15b9&vxp=mtr
or this
http://www.ebay.ca/itm/D2-Racing-RS-...1866c3&vxp=mtr
kits
thanks for all the advice guys, my plan is to close the gap between the tire and fender as close as possible, maybe like an inch or an inch and half. would this be fine? here are some that I'm looking at. please give me your professional and experienced opinions as I'm a noob when it comes to in depth modification of cars.
not sure if for awd?
http://www.ebay.ca/itm/2006-2013-Lex...5a974c&vxp=mtr
http://www.ebay.ca/itm/2006-2012-LEX...a60fde&vxp=mtr
please let me know which is the best one and how I should go about it.
It's all up to you, but most people I know go with BC coilovers since you get to choose the spring rates when you order a new set, and are easier to rebuild. I know Megan makes awd coilovers as well as BC. In my opinion BC is worth the extra money due to higher quality. They will run you around $950-1,000 new. Megan's are around $650-799
Yeah, I agree. Save up a bit for the BC racing coils which offers more dampening settings, better build quality and better handling performance.
I have a budget of 15gs to put on my car the way I want. so money is not a big issue to me and 1000 seems cheap to me so ill probably go with bc coils
If money is not an issue, go with KWv3 coils, that set up is one of the best for handling. http://kw-suspension.com/us/kw_variant_3.php
Kaufy19
08-10-17 11:29 AM
