what's your entire brake set up?
Old 07-01-14, 03:24 PM
mam
mam's Avatar
I am running LS400 4POT front, Supra Turbo 2POT rear, Supra Big Bore Master Cylinder + Slim Booster
Performance, pedal feel, and brake bias are spot-on.
My only complaint is that the LS400 pad selection is very limited.
Old 07-01-14, 04:01 PM
oldManTan
oldManTan's Avatar
how hard is it to replace the master cylinder?
Old 07-01-14, 04:19 PM
fried_rice
fried_rice's Avatar
All master cylinders I've replaced on SC's have said 1 1/16" bore stock, which is supposedly what the TT Supra master is. Just an FYI. NA Supra Master Cylinders are supposedly 1". I haven't seen the OEM masters side by side, so I couldn't tell you if they're actually different. With LS400 front/Supra TT rears and SS lines my pedal feel is perfect and braking power is as good as nearly anything on the road course I've encountered. I can lock the brakes up with ease with 275 front and rear R-Comps.
I have encountered fade/boiling on some tracks when driven at 100%, even with Castrol SRF, at 175RWHP stock GE. I did not have ducting at the time. I plan to duct first, and if necessary switch to Z06 calipers up front.
Old 07-01-14, 05:18 PM
oldManTan
oldManTan's Avatar
i gotcha, i have TT calipers all around and i'll be getting some drilled rotors and SS lines next. maybe later Z06 calipers up front and TT fronts in the back would be awesome. but i think i would need a master upgrade or something then cz thats 20 cylinders then.
Old 07-02-14, 02:11 PM
CatManD3W
CatManD3W's Avatar
LS400 with Drilled rotors up Front and SC300 with Drilled rotors in Rear
I will probably upgrade the rears to TT at some point
Old 07-05-14, 11:27 PM
TheAzn
TheAzn's Avatar
Gotten my SC with Wilwood calipers in the front and rear.
I think the rotors are Supra TT.
Old 07-06-14, 02:29 AM
KahnBB6
KahnBB6's Avatar
Received 1,239 Likes on 866 Posts
I am running Supra TT calipers in the front and rear with stock Toyota TT pads, Centric 120 blank-face rotors up front and OEM TT rotors in the back. Brake lines are Goodridge braided stainless steel all around. Brake fluid is standard DOT 3.
Tires are BFGoodrich Comp2 235 front and 255 rear.
No further caliper upgrades planned for my car. I may try Hawk HPS pads or a Porterfield compound later on when there is more power.
Old 07-08-14, 11:17 AM
oldManTan
oldManTan's Avatar
i'm looking at DBA brake rotors now, they look awesome with their kangaroo paw pattern center. looks like i found my rotors. now some SS lines and my brake kit will be ready for installation
Old 07-08-14, 05:49 PM
Kingboo
Kingboo's Avatar
Thanks for the info!
Old 07-09-14, 03:26 PM
oldManTan
oldManTan's Avatar
this thread turned out pretty good. anyone else care to pitch in their setups? try to be as specific as possible
Old 07-10-14, 12:08 PM
oldManTan
oldManTan's Avatar
sorry for the outside links but i'm really confused as to why http://www.ebay.com/itm/HIGH-PERFORMANCE-STAINLESS-STEEL-BRAIDED-BRAKE-LINE-93-98-SUPRA-SC300-400-BLUE-/181074904032?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ASC300&hash=item2a28e7c3e0&vxp=mtr ebay lines are half the price of techna fit lines and they look identical.
Old 07-10-14, 06:14 PM
Qman4155
Qman4155's Avatar
im running ls430 front disk and caliper
Old 07-10-14, 06:35 PM
marshall2j
marshall2j's Avatar
Supra TT brakes on all four corners.
TT rotors
Braided brake lines
Stock cryogenically treated TT rotors
Hawk HP Plus race pads
Yes, I'm planning on tracking the car, just been ridiculously busy with life to do so :/
Have tested them out mountains near me and they are awesome!
Suspension set up:
TT F/R sway bars
Tein Supra TT Circuit Master Type RE <3
Tires:
245/275 on 18s (not sure on ratio) HTR Z3
EDIT: TT AUTO LSD also
Old 07-10-14, 08:31 PM
kilroy45
kilroy45's Avatar
Default LS400 front
I have 95 LS400 fronts with sumitomo (stock?) Purple pads and brembo oem blank rotors, stock lines but redid entire brake hardlines myself
And sc300 rears with drilled and slotted rotors...stops pretty quickly. I'm very pleased and only paid 80$ Also I have 275/40/17 bf Goodrich G force kdw t/a tires and kumho 235/45 in front (TT wheels)
Old 07-12-14, 12:02 AM
oldManTan
oldManTan's Avatar
anyone got some input on SS lines i posted 2 posts up? i wanna buy them ASAP and don't know what to do. i mean how different can they be? anyone got some input?
Quick Reply: what's your entire brake set up?
