what's your entire brake set up?
Old 07-12-14 | 02:38 AM
  #31
KahnBB6's Avatar
KahnBB6
Originally Posted by oldManTan
anyone got some input on SS lines i posted 2 posts up? i wanna buy them ASAP and don't know what to do. i mean how different can they be? anyone got some input?
I think they look correct in the picture but I have no experience with the brand, sorry. I highly recommend a set of Goodridge SS lines for the SC/Supra. I've used their product on my previous Honda Prelude and my SC300 and they have been excellent and trouble-free. In the picture you have shown there appears to be a nylon or rubber sheath over the stainless steel lines. I've never seen that before so that's a new one on me.
SS brake lines are not very different from one company's offering to the next. I'd just recommend going with a known brand because it's a part of one of the most critical parts of your automobile.
Old 07-12-14 | 10:30 AM
  #32
oldManTan's Avatar
oldManTan
see that's why i picked those because goodridge doesn't have the nylon tubing over the SS. the nylon prevents any dust getting in between the SS and creating friction with the hose underneath, which can shorten longevity. i talked to my paint buddies and they all have track ready STIs and they run technic brake lines, but the ebay ones look the same and half the price lol. i'm just wondering if this is a case of simply cost of the brand.
anyone ever bought ebay SS lines?
oh and goodridge lines on ebay are 60 bucks
Old 07-13-14 | 12:17 AM
  #33
oldManTan's Avatar
oldManTan
ordered the techna fit brake lines. they have good reviews so i went ahead with them.
Old 07-13-14 | 11:12 AM
  #34
scENFORCER's Avatar
scENFORCER
I purchased eBay SS lines in the past and they failed on me. I had to drive the car quite a distance only using the gears and ebrake to stop. Scariest expeierience of my life.
Anyways, the part that failed was the connector on the ends. They were made out of aluminum (which is weak) and they failed only after about 6 months of regular street use (no track).
I will say though, that I can't say if it was installation error (as they worked fine for 6 months) or a poor product (as I'm not sure if ALL SS lines come with aluminum fittings). Either way, with something as critical to your wellbeing as a brake system, I highly suggest not cheapening out on parts - you're "upgrading" afterall, right?
Old 07-13-14 | 01:24 PM
  #35
oldManTan's Avatar
oldManTan
yea i ordered the legit ones not ebay lines. i need to call them tmr though to verify my address because apparently my address doesn't exist in their records
Old 07-24-14 | 11:18 PM
  #36
SC3paul's Avatar
SC3paul
Hey guys, thanks to everyone for posting their brake setups.
I have a question..I searched quickly but didn't find the answer..maybe because the answer is obvious...
My question is when you swap out stock calipers for something like TT calipers or LS400s or even swap older SC300 calipers for SC400's do they just bolt right right up and nothing else needs to change, like spindles etc? I assume you at least have to use the correct rotor size for the calipers, but other than that just bolt on the bigger calipers? thanks...
Old 07-24-14 | 11:51 PM
  #37
oldManTan's Avatar
oldManTan
yep all toyota calipers just bolt right on, nothing needs to be changed at all except the right rotor size. if you want Z06 calipers then you'll need to make a bracket and i think someone on here posted that has that set up and he makes brackets for em.
Old 07-24-14 | 11:53 PM
  #38
oldManTan's Avatar
oldManTan
got the lines, will try to install them tomorrow (friday) hopefully my girlfriend won't be too distracting and will help me out lol. also will paint the calipers and will order the DBA rotors soon, hopefully...
Old 07-25-14 | 07:39 AM
  #39
Kris9884's Avatar
Kris9884
I have LS400 front calipers, stock everything else. It's marginally better than stock
I'll be replacing with C6 calipers, all rubber with hard and SS lines.
My question is what type of booster and brake cylinder is an upgrade? Never looked into them.
Old 07-25-14 | 01:44 PM
  #40
scENFORCER's Avatar
scENFORCER
^ I'm doing the C6 upgrade as well (got the brackets sitting in my bedroom, just need to save up for everything else), but as far as I know the stock master-cylinder works fine. As long as it works correctly there should be no difference or 'upgrade' needed to be done here, its all the calipers work that is the upgrade.
Having said that, in the LRD's thread about the Vette breaks there is some talk about using a TT master-cylinder. Although I'm not sure if anyone actually did it or had any benefits from it..
Old 07-25-14 | 11:59 PM
  #41
oldManTan's Avatar
oldManTan
yep his thread is the place to go for C6 caliper talk
Old 08-04-14 | 07:18 PM
  #42
Halon's Avatar
Halon
FRONT:
TT Supra calipers
ABT slotted zinc rotors
Ceramic pads
GT Autosport SS braided lines
REAR:
Supra NA / SC400 calipers
Ceramic pads
(clears my 16" FD drag wheels setup)
Old 08-19-14 | 01:51 PM
  #43
oldManTan's Avatar
oldManTan
discs came in, gonna replace them this weekend so my brakes will finally be done
Front:
TT Calipers
TechnaFit SS Lines
DBA 4000 Series Brake Rotors
Rear:
TT Calipers
TechnaFit SS Lines
Stock TT Rotors
that's probably my final set up now. nothing else left to change.
Old 08-26-14 | 12:24 PM
  #44
CatManD3W's Avatar
CatManD3W
Heres my setup
Front: LS400 Calipers, R1 Concepts slotted rotors, Ceramic pads
Rear: SC300 Calipers, R1 Concepts slotted rotors, Ceramic pads
Old 09-19-14 | 09:34 PM
  #45
SCV8's Avatar
SCV8
TT front calipers, eom rotors and pads.
Stock sc rear rotors with TRD (Performance Friction) pads.
Oh, and you do need to nibble, and or bend the front backing plate/ shield just a bit when installing the larger calipers.
Jonb42
04-24-13 06:13 PM
lengnoou
Suspension and Brakes
10-09-09 08:30 PM
renren7
07-06-09 12:52 AM
TGRich
12
03-16-04 09:48 PM
SupraCoup3
SC- 1st Gen (1992-2000)
06-20-02 07:37 PM
Quick Reply: what's your entire brake set up?
