eibach is250 pro kit on an is350.....would you do it?
Hey guys, I have an*08*IS350*and I just installed the*F-sport*rear*sway*bar. Now I want to lower the car. I am set on the*eibach pro kit*but i am thinking about using the pro kit for the 250 because of the*lower drop. The only diff between the two sets is the initial spring rates of the front springs. (29 lbs)
Pro Kit*IS250*8288.140*Spring rates front 199-to-314
rear 217-to-354*
Lowering front 1.4" rear 1.0"
Pro Kit IS350 8287.140 Spring rates front 228-to-314
rear 217-to-354
Lowering front 1.0" rear .8"
Would you guys do it? And if you have done it already, what's the verdict? Good? bad?I'll be using stock shocks and I only drive around 10k miles a year.*Thanks for your guys' input!!
rear 217-to-354*
rear 217-to-354
I think either spring will work on both the IS250 and IS350. I haven't done it myself but I heard that they are compatible.
https://www.clublexus.com/forums/sus...-an-is350.html
I have the Eibach IS250 version on my IS250 and it handles better and feel firmer than stock. 1.4 front and 1.0 rear is also perfect lowering for my daily driver as I don't have problem driving in and out driveway.
I think the premature shock wear is related to how stiff the spring is, not how low they are. In general though, the lower, the stiffer the spring rate and therefore, some might think that the lower the spring, the faster it kills the shock. However, it is the stiff spring rate that does is.
Since both Eibach versions spring rates are very similar, they should affect the shocks similarly.
The springs rates of the eibach 250/350 are much softer than the f-sport by eibach. Guess this is the reason why f-sport springs are stiffer/firmer compared to the eibach 250/350
eibach rates
these rates are not bad for progressive springs
Pro Kit IS250
Spring rates
front 3.5kg/mm initial rate to 5.6kg/mm final rate
rear 3.8kg/mm initial rate to 6.3kg/mm final rate
Pro Kit IS350
Spring rates
front 4.0kg/mm initial rate to 5.6kg/mm final rate
F-Sport are a lot stiffer and as you install the springs when the weight of your car sits on the springs the rates already increase
F-Sport by Eibach
4.7kg/mm initial rate front
4.0kg/mm initial rate rear
6.6kg/mm final rate front
7.0kg/mm final rate rear
Lexus should have stuck with the eibach 250/350 rates instead if redesigning the f-sport springs to the stiffer rates
Pro Kit IS250
Spring rates
Pro Kit IS350
Spring rates
F-Sport by Eibach
nal831
Suspension and Brakes
07-10-14 02:06 PM
