Front right side Wheel Vibration when turning left
Hi All
Please advise what could be the problem. When I turn left at low speed on paved surface, I get a vibration on the right side from wheel. It can be felt into the stering column.This dont seem to be the case when I turn at the same speed on tar surface.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
Hi Thanks for the feedback.. its rear wheel drive.
For some reason this noise has gone away. However, at high speed I can still slightly here a noise that sound as if there is a protruding ball on the tyre wall so it sounds like a thumping noise. The front wheel disc was replace and I’m not sure if there is or was a spot on the right hand side disc that was coursing this noise. I have not removed the wheel yet to inspect. Could it be a wheel baring that is starting to wear out.
Oh yes and my air bag light has come on and stays on....any advice......
lexluthr1x
05-24-15 08:11 PM
