Spacers on F-sport on OEM suspension
I'm considering spacers for my car. I've read the thread about the Ichiba spacers and will likely go for h&r or project kics. What is the general consensus around using spacers at stock height? I've read that 20mm can sometimes rub (in case I lower in the future) and as such, I'll probably go 15mm. Does anyone have any suggestions on where they can be ordered? Any pics of 3IS with spacers on stock suspension? Thanks
Check out TheShaddix's build thread. Post 1 on that thread shows his car with stock suspension on 25 mm spacers. https://www.clublexus.com/forums/bui...ld-thread.html
I'm running 20 mm AKATA spacers all around with RS*R Down Springs and I don't have an issue with rubbing. There are a couple people that runs 25 mm front and 20 mm rear with minor issues.
As for where to get the spacers, I got the AKATA off of eBAY for an awesome price. You can also find brand name ones at http://www.b2autodesigns.com/index.php?cPath=45_47
GL.
GL.
Anywhere after 20mm, it just depends on how low you are.
I'm on coils and have 20mm rear spacers, and would rub going up a driveway, because my car is slightly too low. Flush stance is the best stance.
I don't think you need any spacers at all unless you want to poke your wheels out which could create more work/problems for you. What you would probably need to do when lowering your car are adjustable rear camber kits (I think the front ones are adjustable to some extent). You might also need to roll your fenders if it starts rubbing on your tires once the springs settle down after some time the car has been sitting on it.
Spacers are not needed for lowering your car. It just makes the stock 18s look awesome! LOL it doesn't add 5 lbs per corner...
You can see it in my build thread here.
https://www.clublexus.com/forums/showthread.php?t=743129
the springs only lower about an 1-1.3inches! and i would be buying 19's. dont think i will have a problem with rubbing or anything in that matter.
ddvette9
Suspension and Brakes
03-05-15 08:31 AM
