Confirmed (With Pics): Supra Lower Control Arms LCA's on Lexus SC-300
Why would you not just change the bushings and ball joint if the original arm is aluminum? aluminum would be lighter and provide better handling due to the lower un-sprung weight.
Can anyone else comment on this? I had to search a bit to find where I had seen that the stock SC LCAs are aluminum -- not sure if this was the only thread or if there were others I saw -- but I mentioned it to SC3coupe and he was skeptical, so he suggested I check with a magnet. Sure enough, my front LCAs are magnetic, so definitely not aluminum. However, I can't say with any certainty that a previous owner didn't change them somewhere along the way.
It's tough to tell in the picture if the LCA on the left is unpainted aluminum or just really dirty black (cast iron)... Me2, were you able to tell a difference in weight between the two? That is, if you ever check back in.
Five posts total, having started this thread seven months ago, suggests that's unlikely.
Hi, im new to this thread. Im about to buy a 1992 sc400 and i think it needs new ball joints, upper and lower. it has the occasional clunk feeling when driving down the road, and i can tell its coming from the front left. It drives as straight as an arrow down the road. I have done some research and the LCA's are ridiculously priced but have found (thanks to this thread) that supra lca's fit perfect. My only question is if the JZA70 supra LCA fits as well, because that LCA is even cheaper than the mkIV supra LCA. Thanks!
JZA70 Suspension is not compatible with SC300s or Supras.
All LOWER CONTROL ARMS (Front and rear, left and right) are cast steel. This is the same for SC and Supra. Be aware that Supra Rear LCAs are shorter than SC.
All 4 upper control arms are aluminium.
Also to add for those new here, the ball joing on our control arms (lower) is not replaceable. when they go bad you have to replace the entire arm. thats why its better to just do the whole supra arms so you get new bushings, balljoints, the works. if you just do new bushings on tired old SC ball joints, you might still have a loose/wandering steering feeling.
also the bushings in the supra arms are more firm than our arms and should last longer, so its an upgrade as well.
Swapping them out can be done, but you're talking about retooling the metal with specialized cutting tools or acetylene, then trying to find the right ball joint, welding, etc..just get new arms that have newer structural integrity, fresh paint, and IMO spray them with a coat of anti-rust.
When I bought my car I vin checked it on Lexus.com and one of the last times the car was taken in they recommended replacing the LCA's. It still drove better then any other car I've driven but now just two years later every bump feels harsh. When replacing my front calipers last week I noticed one bushing looked completely shot, and now I'm getting a grinding feeling from the front right of my car when coming to a full stop...
I can confirm that all of the upper control arms from a 1998 Supra T.T. fit on my 1998 Lexus SC400. I also replaced my front lower control arms with the 98 Supra ones at the same time as well as the front sway bar end links. The REAR 98 SUPRA T.T. sway bar end links are NOT COMPATIBLE. I also installed both sway bars from my supra. I just finished installing all of these parts as well as the front and rear struts and springs. Rear upper control arms were probably the worst installation of any part that I have ever attempted to install on a car due to absolutely next to no clearance.
