any of u modify megan rear camber kit OR suggestion for an aggressive camber kit ?
my rear megan camber kit is maxed out and my car is more like "hella flush" as it is. Its really scare me to drive this car daily. Fender literally hit the wheel lips when i went through a pot holes / train rack in faster speed. I'm trying to achieve "tucked flush" look.
Is there more aggressive camber kit out there that doesnt cost arm & leg ? Or have any of you modify your rear camber kit to get additional -1 or -2 degree ?? Mine is on -5 right now. my other solution is change my rear wheels to be 20x10 ( its 20x10.5 right now ).
How low are you?
I was dumped on coilovers and I got -6.9 out of the box from Megan Uppers (2) and Megan Toe arm with 10.5 width before final adjustment to -4 on the rear.
Let me know..
Let me know..
damn maybe i should install the upper arm as well.
here's his thread:
https://www.clublexus.com/forums/sho...d.php?t=727974
i'm sure you can still pull them
here's his thread:
here's his thread:
thanks for the link tho.
woa...so rear upper megan arms actually helps??? i have it but i didnt install it cuz seems like most of u guys only install camber n toe arms. mine is not that low actually. about 1-1.5 inch between lips and rear fender.
I'm currently tucking 265/30/19 on a 19x10 +20 wheel cleanly (almost zero stretch) and my fenders were shaved completely at Sonic MS. You just gotta find the right shop. Too bad you aren't in NorCal
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Another solution is to shorten the camber arms which includes cutting and re-welding it. I can't explain much about it but a CL member on here did it. His ride height rear camber is -10 and his aired out camber is -13. I forgot his ig name but he's in the marketplace for the IS250 parting out. o7is250 I think
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Imnutz4jdm
02-29-12 04:47 PM
