SuperPro Polyurethane Steering Rack Mounting Bush Kit 47 mm or 50 mm ?
i want to order a set of SuperPro Polyurethane Steering Rack Mounting Bush Kit but they come in two measurements , a 47 mm set and a 50 mm set , i tried searching what our sc400 1992 are using but i can't find a answer
anyone could help me out ? after reading so many positive comments on poly bushings i really want to get tighter steering too
copy /paste the advert ;
Fits: Lexus SC300 & SC400
SuperPro Part No. SPF1193-47K - To suit a 47mm diameter steering rack.
These cars are fitted with two diameter steering racks either 47mm or 50mm. Bush kits for both racks are available here.
I bought steering rack bushings and it didn't look like that, i think this is what your looking for http://www.whiteline.com.au/product_..._number=W11970 or for super pro
http://www.superpro.com.au/superpro-...1&vid=99001750
I bought the whiteline bushings, i dont know if i felt a difference, but i knew i did when i did my control arms!
yes but superpro has the Steering Rack & Pinion Mount Bushing
Replaces OEM 45517-14040,suited to vehicles with steering rack housing outside diameter of 47mm
and the Steering Rack & Pinion Mount Bushing
Replaces OEM 45517-24030,suited to vehicles with steering rack housing outside diameter of 50mm
thanks for your help
