Lowering my SC3; worried about exhaust. Pictures and video within.
Old 06-25-14, 05:39 PM
deputy865
deputy865's Avatar
Default Lowering my SC3; worried about exhaust. Pictures and video within.
Long story short, I bought some new wheels, tires and coilovers and I've got a laundry list of things to do before they go in!
One of them is my exhaust. I'm worried it sits too low and will scrape frequently when I drop my car.
Do I need to do anything with it? I don't want to put a hole in it, or worse, snap it off at my turbo, etc.
Car is at factory height in pictures on 18" wheels with 40 sidewall all around.
Goal will be to have a flush look with the new set up and no finger gap between well and wheels.
New wheels are 19" front and rear with a 35 sidewall up front and a 30 sidewall in the rear.
Exhaust is a full 3". I'm 1jz swapped, single turbo, which is reasoning for the 3"
Thanks for any input.
From front of car:
Rear of car
Measurement at downpipe; about 3.5" from floor to pipe.
Middle section at a flange; roughly 3.5" of clearance
Rear section, close to 4" of clearance
Old 06-26-14, 08:28 AM
ashtray
ashtray's Avatar
My exhaust has 1 high flow resonator in there and it rubs on everything. I'm always afraid of it cracking I just havent had it fixed : (
Old 06-26-14, 08:58 AM
hmhatch
hmhatch's Avatar
Just don't lower the car too much. Simple.
Old 06-26-14, 09:09 AM
deputy865
deputy865's Avatar
Is there anything I can do to get it pushed up further? Or am I about as good as it gets?
It looks like there is more space, but the down pipe is pretty snug.
If you haven't noticed, I've never owned a lower car
Shane
Old 06-26-14, 06:25 PM
turbodremz
turbodremz's Avatar
You should be ok. I run a 3.5'' dual exhaust on my SC with my LS swap, and while I do scrape at times, its generally minimal and over speed-bumps. When I did have my 2JZ in, I ran a full 3'' turbo back with similar minimal ground contact, and the streets here in Houston are horrible.
If you concerned about creating holes in your exhaust from scraping, weld a skid-plate to the low points of your exhaust pipe.
Old 06-26-14, 06:27 PM
Toyboxx
Toyboxx's Avatar
I'd go to a local exhaust shop, and have them tuck it up a bit. Shouldn't cost to much as they're essentially cutting and re welding brackets.
05RollaXRS
GS F (2016-present)
12-20-17 08:04 AM
jdubbsISF
RC F (2015-present)
12
08-12-15 04:51 PM
Bubbas SC
SC- 1st Gen (1992-2000)
46
05-06-11 08:44 AM
Rash
04-06-11 11:14 PM
Sceptre
Performance
10-15-09 05:07 PM
Quick Reply: Lowering my SC3; worried about exhaust. Pictures and video within.
