How do Sprint Lowering Springs
compare to the rest of the springs out there? I am planning to lower my car with L tuned shocks and want a good set of springs as well.
Guest
Posts: n/a
Well
I actually contacted them about thier product. I was interested int eh 2" drop. They gave me a response that did not convince me to try their product. Basically, it is made of the same_______blah blah blah as everyone else.
I think some IS guys have em.
From my understanding the GS has camber adjustments. I don't think you need a camber kit. With a 2 inch drop you should fine or very close to having a balanced camber. Even if you or a little on the negative side, at least you will get better handling.
Ok nvm my post, didn't see that a camber kit is coming out.
Hi GSjason. I have a set of Sprint lowering springs on my 99 GS and I love them. They are the 2" drop and at the time I was searching for springs, I bought Sprint because they seemed to have the lowest drop of all. Eventually, I will be going to coil- overs,but for now no complaints. The ride is not even as harsh as I had expected,even with 235/45/17 tires.I feel I made a wise decision.Good luck in your spring choice.
is250916
Suspension and Brakes
14
05-30-14 11:53 AM
