RS-R Half Downs Question
For those who have them or are familiar with them, do the install instructions require the bump stops to be cut?
Thanks in advance.
Thanks in advance.
If you had your choice, what would you do?
Im typically really picky about what I put on my car. I had a STI that had springs that I was not very happy with. The ride completely changed.
Thank you for your input...
Since the springs are made to work with Stock Coils, are they good on performance, Ride etc...?
Thank you for your input...![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I'm going with the RSR half downs springs because I believe they strike the best balance between comfort handling and looks at a good price. Would I like it a little lower? Sure, but I don't want to sacrifice much in ride quality. The spring rates on the half downs are a little softer than the similar Tein H-techs so the ride should be better. My previous car (Acura TL 6MT) had H-techs and it was just right for me.
Personally, if it wasn't for the variable suspension on f sports, i would buy a coilover set. You just have lot more options with coilovers for both performance and looks and many company's have very affordable rebuild program on their coilovers. But i would like to utilize variable suspension feature since it is my DD.
