Howling Noise Only @ 40mph
Old 08-30-14, 09:06 AM
Behemoth7
Behemoth7's Avatar
Default Howling Noise Only @ 40mph
Is this a symptom of bad wheel bearings? It just started happening after I had my suspension bushings installed and new intermediate shaft.
Old 08-30-14, 02:58 PM
k7q
k7q's Avatar
does it get louder the faster you go? if so, sounds like a wheel bearing. bad tires (uneven wear) can cause howling noise also.
Old 08-30-14, 05:56 PM
Behemoth7
Behemoth7's Avatar
No it only happens in the 40 -45mph range. Maybe I'll have to go get the tires checked out again.
A couple months ago I got stuck in a ditch and was spinning the wheels in the dirt. Could that have misshapen the tire and be causing the noise?
Old 08-30-14, 07:46 PM
NorthStyle
NorthStyle's Avatar
It sounds like a wheel bearing to me.
Old 08-31-14, 08:56 AM
Behemoth7
Behemoth7's Avatar
It doesn't get louder with speed though, at highway cruising speeds, the noise is non existent.
Old 08-31-14, 03:26 PM
NorthStyle
NorthStyle's Avatar
It doesn't necessarily have to... For example: I had a MK3 Jetta that, when the bearing was needing to be replaced, only made the noise between 65-70 mph; other than that it was quiet.
Old 08-31-14, 04:55 PM
Behemoth7
Behemoth7's Avatar
Does a bad wheel bearing make a consistent noise? Because mine is intermittent.
Old 09-02-14, 12:29 AM
islexusred
islexusred's Avatar
did you ever install the differential bushings? if yes any feedback?
Old 09-02-14, 06:37 AM
repugnante
repugnante's Avatar
Both. It can be intermittent and/or it can be constant. Depends on the damage of the bearing race. You mentioned that you were stuck in the mud and your wheels were spinning out to get out of it. Depending on how deep that wheel was submerged, that could be the cause of a failed wheel bearing. Two main causes of bearing failure: hitting a curb when you park, moisture (driving hard through puddles).
Go to each wheel and hold it by the 12 and 6 o'clock position. Push and pull to check for any play. I'd do this for all wheels because you won't be sure on what wheel is affected. I had bearing noise in one of my cars that sounded like it was coming from the front but it was actually one of my rear wheels that had gone bad.
Old 09-02-14, 09:41 AM
Behemoth7
Behemoth7's Avatar
Yeah sorry I've been meaning to post back, those bushings worked like a charm! No more clunking and acceleration is much smoother.
And I'm having the car checked out as I write this so I'll update when I know more.
Behemoth7
12-02-14 10:34 PM
honasbone
10-14-14 02:02 PM
erale
RX - 1st Gen (1999-2003)
07-15-14 08:23 AM
mikeybee21
08-09-11 03:46 PM
sbgs400
GS - 1st Gen (1993-1997)
11-24-02 01:14 AM
Quick Reply: Howling Noise Only @ 40mph
