F Sport Springs
So i should have my new wheels on by friday, and I am looking into buying a pair of lowering springs. I really believe in the f sport stuff as it was designed and tested and track proven by Lexus themselves. With that being said, the drop is not quite as drastic as some of the other springs. So, two questions
1. Will the drop be low enough to get rid of the wheel gap on 18" wheels with 255/40 and 235/40 tires
2. Will the springs alone stiffen up the car, or is that mainly the struts?
Fsport springs will give you about a finger to a finger and half gap for 2is RWD 18inch oem wheels. If you want performance and about the same drop height. Go with Swift springs.
http://www.evasivemotorsports.com/mm...de=SWIFT-4T040
Yea I was just reading that on an other post. I like a firm ride
You may want to check on tein h-tech also almost the same drop of F-sport mine is still on the stock 17" rims so it's a 2 finger drop all around but yes upgrading to 18" or 19" may close out the wheel well a little bit more since in the tire calculator it will add at least .4" or 11mm to the wheel and tire size
Speed3381
GS F (2016-present)
02-27-17 07:51 PM
fooddude
05-20-14 05:44 PM
Joe Z
Suspension and Brakes
17
06-16-11 06:20 AM
