Rear Camber Adjustment on 2015 Models?
possible to get the arms with rubber bushing right now and replace it with the "official" bushings later on?
Yes I decided we will release with the rubber bushing and move to the lifetime poly in the near future. We are looking at a late Jan full production ramp. but I am seeing how many we can get out before then.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
We have opened our preorder as well and we will have both upper links with the same options we have on the 3GS which is camber correction or negative camber. The #2 arms will eventually get polyurethane bushings. We should be able to support a wider range of adjustment on this arm in our version.
Thanks Mike
http://shopfigs.com/v1/index.php?rou...product_id=280
3IS 4 GS rear upper links. Camber kit
Thanks Mike
__________________
Just a question on these adjustable arms, would i be right in saying that to correct the camber the top arms would wind out the top of the tyre?
Reason I ask is my 275's are close to the fender now & winding the top out to correct camber would probably have the tyres rubbing.
Mike
__________________
We are shipping, all parts in house and ready to assemble. Also first articles of poly bushings have arrived. We will verify them and they should be soon to follow.
__________________
__________________
