How wide are yours?
Installing some Niche 20's on my Fsport today.. How wide are all your guys tires? If your runnings 20's that is? 265? 275? and if you lowered your baby how low did you go? Any fitment issues? rubbing?
I have 20x10.5 on the rear with +45 offset, running 275/30/20 and I am about to lower it with coilovers but prior I was going to do springs and although everyone on the forum says ut will rub in the rear, I got on the phone with Tein's California offices and we did some math together and I am fairly confident it wil not rub at all.
Hi. I am running 20x10.5 +45 on my rears with a 255/30/20 setup lowered on RS*R Down Springs. It is a stretched tire setup so no rubbing issues. I have a couple friends with different setups but are also lowered with 20" wheels. One is running 20x10 +45 245/30/20 which is an even more stretched setup but he is a lot lower than I am. The other one ran 20x10 +45 255/30/20 with RS*R Super Downs which is about a 2" drop and no rubbing issues. I would suggest going with the same setup I am running to avoid any issues and/or fender rolling/pulling. Let me know if you want to see picture comparisons between all of these setups.
mdgrwl
08-31-09 08:47 PM
